Author Topic: Bmt 250 setter  (Read 517 times)
Offline Chaser357
Bmt 250 setter
« on: February 20, 2019, 05:25:28 PM »
Got my bmt 250 in a month or so ago and just got around to setting it up.   What a tedious process.   Anyway finally got it going and is setting consistently.  Iíve set two blades with it now the power is intermittent.  Holding the jog button down it will go on and off.  Called woodmizer and I think we are on the right track towards getting it fixed.   Think the power transformer is bad.   Just my luck.  Anyway looks like Iím gonna like it but it is very tricky getting it set just right.
It came with a brand new 9/16 wrench in the box and I donít know why.   Not saying I donít want it just wondered what it was in there for.  I used a lot of tools setting it up but a 9/16 wrench was not one of them.
Also got the bms250 sharpener with the turbo 7 wheel and it does a great job.   Very pleased with it and it was a lot simpler to get going than the setter.
Never sharpened or set a blade before and the sharpened one performs just as good as new.  It only took me a week to set these two machines up and get two blades sharpened.  ;)
Offline tawilson
Re: Bmt 250 setter
« Reply #1 on: February 20, 2019, 06:03:10 PM »
I need to call Woodmizer and demand my wrench. Lol. I think there may be someone in Indianapolis looking for his wrench.
2017 LT40HDG35 WIDE
Online Woodpecker52
Re: Bmt 250 setter
« Reply #2 on: February 20, 2019, 06:15:30 PM »
For the recreational saw filler the best tool I have used lately for sharpening my bandsaw blades is a small flat diamond whetstone, works better than pink wheel, Dremel wheel, small diamond wheel or small metal file, a close second is just a plain old small whetstone it will put a razor edge on the teeth. Please note I only sharpen 1-2 blades by hand and it takes about 10minutes each, but it saved me about $1,000.  I made a very good blade holder which is the key also.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
Re: Bmt 250 setter
« Reply #3 on: February 20, 2019, 06:29:43 PM »
I'm still trying to figure out what to do with the 9/16 wrench also.
My new mill came with 10's and I was not impressed, yet on the old mill I swore by 10's
I am going to order a box of turbo's and the stone to go with them.
Offline Chaser357
Re: Bmt 250 setter
« Reply #4 on: February 20, 2019, 06:45:59 PM »
If youíve got the hp to pull it you will never look back once you get the turboís.   Iíve only got 27hp and I would not want to be much lower than that.  I push them as hard as I can without choking the motor down.   The harder you push them the smoother they cut.
Offline Stephen1
    • muskoka Sawmill
Re: Bmt 250 setter
« Reply #5 on: February 20, 2019, 06:48:53 PM »
Thats what i'm hearing, saw fast.
Online Southside
    • White Oak Meadows
Re: Bmt 250 setter
« Reply #6 on: February 20, 2019, 07:37:29 PM »
Turbos and Carbide 7's are the only profiles I have for both mills now.
White Oak Meadows
Offline Stephen1
    • muskoka Sawmill
Re: Bmt 250 setter
« Reply #7 on: February 25, 2019, 09:12:50 AM »
SS are you sharpening the carbides? Do you set the carbides?
What wheel are you using?
Online Southside
    • White Oak Meadows
Re: Bmt 250 setter
« Reply #8 on: February 25, 2019, 10:19:27 AM »
Have not had to yet.
White Oak Meadows
question
Better setter
Started by uler3161 on Sawmills and Milling
Last post December 05, 2014, 06:18:06 PM
by uler3161
NEED A SETTER
Started by SAW MILLER on Wanted
Last post March 24, 2006, 08:21:11 PM
by SAW MILLER
Setter
Started by ladylake on Sawmills and Milling
Last post January 10, 2018, 08:33:34 AM
by ladylake
My New Setter
Started by Fla._Deadheader on Sawmills and Milling
Last post February 20, 2003, 04:07:32 PM
by Fla._Deadheader
