Author Topic: Upgraded to a better Moisture Meter  (Read 356 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
« on: April 21, 2019, 03:43:58 PM »
After listening to the Kiln presentation at the GA project and the knowledge shared by @WDH @YellowHammer I decided to up my game on moisture meters. Up until now I have been using a pinless Wagner meter I got from WM years ago.  Over the past year I was always frustrated with the readings. Using it inside my kiln was useless most of the time and even boards taken out of the kiln the readings were all over the place. I am aware that it is a density meter but the readings I get over a board are just unacceptable when selling kiln dried wood. Today I ordered the Delmhorst meter with the sliding hammer probe. I hope this meter will give me more accurate readings inside and outside the kiln.
The wagner has its uses I propose, but the readings are just to sporadic for my liking.
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline GeneWengert-WoodDoc
Re: Upgraded to a better Moisture Meter
« Reply #1 on: April 21, 2019, 04:01:12 PM »
The pinless meter is awesome for checking kiln dried lumber in a manufacturing plant.  It is also widely used for checking softwood construction lumber...it is so fast indeed.
Offline KenMac
  • I'm new, but don't feel so new!
« Reply #2 on: April 21, 2019, 08:14:02 PM »
What is the recommended model Delmhorst? J2000? Which particular accessories are needed? I also need to upgrade.
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: April 21, 2019, 08:20:09 PM »
I have the J2000X with the slide hammer. The "X" model is supposed to be good for kiln use.
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #4 on: April 21, 2019, 08:39:41 PM »
The J2000 style is the meter I use, its got a shunt calibration and is very consistent.
HobbyHardwoodAlabama.com
« Reply #5 on: April 21, 2019, 08:41:13 PM »
The hammer probe is called a 26ES
Moisture Meter
Started by warren46 on Drying and Processing
Last post September 11, 2013, 12:15:54 PM
by warren46
Looking for a moisture meter
Started by JFarmer on Drying and Processing
Last post July 07, 2012, 04:27:11 PM
by YellowHammer
Moisture meter
Started by rbarshaw on Drying and Processing
Last post August 16, 2004, 08:32:01 PM
by rbarshaw
Moisture Meter
Started by wng-2 on Drying and Processing
Last post March 15, 2017, 07:00:47 AM
by GeneWengert-WoodDoc
