Author Topic: WM - 6' bed extension  (Read 468 times)
Offline E-Tex
  • Rather be Saw'n or Fish'n
    • www.L2Sawmill.com
« on: May 07, 2019, 01:30:11 PM »
I run an LT-50 and considering buying a 6' bed extension.
I mostly do mobile milling for others.  Is a bed-extension even practical for going mobile?  I'd be concerned about setting up level out on location.
Or, are these meant for a permanent/stationary setup?
LT-50 Wide, Mahindra 6065
L2 Sawmill LLC
Offline GAB
Re: WM - 6' bed extension
« Reply #1 on: May 07, 2019, 02:29:19 PM »
If you have a cable track then a 6' extension is all you can use so I am told.  I have no experience with an LT50 or a mill with a cable track.
If you have a walk with the head mill, I would suggest buying a 12' extension.  I purchased a 6' extension and it was a mistake.  First time I used it I needed a 12'.
When the extension bed is bolted to the main mill, in my case, the mill is no longer mobile.
My reply to your question: Is a bed-extension even practical for going mobile?
Is the job large enough to warrant the work involved in mating the two in the field and unmating when the job is complete?  I would be charging a handling/set-up charge.
Gerald
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: May 07, 2019, 08:16:05 PM »
I think Jim Rogers goes mobile with his 6' extension, but I don't know if he takes it apart to move it.
I got a 24' extension, and the first time I used it. I needed a 6' also.
Offline E-Tex
    • www.L2Sawmill.com
« Reply #3 on: May 08, 2019, 12:59:32 PM »
@Jim_Rogers   -  do you go mobile with a 6' extension?
Is it a major pain to set up and get level out on a jobsite......(on not so perfect, level ground)?
Thanks!
Dave - that's impressive.  I'd love to be a  part of milling timbers that length sometime!  Very Impressive.
L2 Sawmill LLC
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #4 on: May 08, 2019, 01:13:07 PM »
I have taken it to job sites. But I trailer it or have a friend with a pickup and tailgate crane move it for me to the site.
I don't try and take it with/on the mill.
I don't have any problems setting it up on gravel driveways or other hard surfaces.
Takes about an hour to hook up or un-hook. I charge an extra fee for moving it and for sawing longer than 16' on site.
Jim Rogers
Offline E-Tex
    • www.L2Sawmill.com
« Reply #5 on: May 08, 2019, 01:22:54 PM »
good info, thanks
L2 Sawmill LLC
Offline thecfarm
« Reply #6 on: May 08, 2019, 01:31:21 PM »
Dave,I always enjoy seeing that picture.
Bed extension on WM
Started by Minnesota_boy on Sawmills and Milling
Last post February 14, 2003, 04:54:53 AM
by Fla._Deadheader
Want Bed Extension for LT-15
Started by WoodHacker on Wanted
Last post October 26, 2010, 05:18:21 PM
by WoodHacker
Need an Extension
Started by MemphisLogger on Wanted
Last post November 29, 2005, 10:33:42 AM
by MemphisLogger
WM Bed extension
Started by customsawyer on Sawmills and Milling
Last post October 30, 2006, 06:18:09 PM
by 4woody
