Author Topic: Black Cherry  (Read 1598 times)
Offline Pete and Jesse
Black Cherry
« on: September 10, 2019, 03:50:18 PM »
I have 1500 bf of black cherry logs that were cut in March. Can they be used for anything besides firewood. DBH is between 20-25".
Offline doc henderson
Re: Black Cherry
« Reply #1 on: September 10, 2019, 04:42:31 PM »
throw them on a mill and see what you got.  are they solid?
Re: Black Cherry
« Reply #2 on: September 10, 2019, 05:02:06 PM »
Yes they are solid. Any suggestions on length/thickness of boards. Just measured one and it is 19" at end of 50' log.
Offline Resonator
  • Board Footage and Cord Woodage
Re: Black Cherry
« Reply #3 on: September 10, 2019, 05:43:35 PM »
Few tips from my experience with Black Cherry:
Buck the logs to straight lengths (cut long as manageable), Anchor Seal the ends.
Saw 4/4 boards as wide as possible, box the pith, and edge the boards to remove as much sapwood as possible.
After drying plan to re-rip boards to straighten any split, crook, cup, bow, etc.
Black Cherry likes to dry fast, which can be bad because it causes defects, but good for air drying to get MC down.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Black Cherry
« Reply #4 on: September 10, 2019, 05:44:06 PM »
Cherry is a high value wood.  Trim the sap off and cut them.
HobbyHardwoodAlabama.com
Offline Woodpecker52
Re: Black Cherry
« Reply #5 on: September 10, 2019, 06:17:35 PM »
The heartwood stays good forever don't waste them as firewood.  They are a great wood used for smoking meat.  I have a kitchen table I made of cherry years ago still beautiful, I think I used a linseed finish.  A definite good wood to sell.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Black Cherry
« Reply #6 on: September 10, 2019, 06:32:20 PM »
   I cut them into 4/4 boards and 8/4 live edge slabs. If you have a real sharp curve cut on both side of it and make a set of curved benches. I had a good sized butt log with a lot of sweep so I cut it into 3" thick live edge slabs for fireplace mantels then I squared off the back so I had a curved, live edge front about a foot wide in the middle and 7-8 inches on each end and sold a pair of them to a guy with 2 fireplaces who fell in love with them. Save your short boards for cutting boards. People like to cut them into narrow strips and alternate the dark red color with white like ash or maple and dark brown from walnut. So yes, save them from becoming firewood.
 These are oak but an example of what you can do with curved pieces.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Black Cherry
« Reply #7 on: September 10, 2019, 07:00:10 PM »
Turn the logs so that when you "saw through" you are sawing parallel to the pith check, otherwise every board in the center will split and look like a banana peel.
Re: Black Cherry
« Reply #8 on: September 10, 2019, 07:51:35 PM »
Would it be best to dry this in the hay mow or greenhouse?
Re: Black Cherry
« Reply #9 on: September 10, 2019, 08:02:57 PM »
Itís best to dry stickered cherry in an unsided shed, no sun, no rain, very little wind.
Put another stack of wood on top as weight or the top few layers will bow badly.  Saw it as @Magicman says, isolate the pith check.  Remove the sapwood as much as possible.
Offline Brad_bb
Re: Black Cherry
« Reply #10 on: September 10, 2019, 08:59:21 PM »
I'll reiterate, trim the sapwood (the white part) of the boards.  It tends to pull boards into potato chips as it dries and shrinks much faster than the heartwood.
You could make 4/4 boards (rough saw 1.125 thick), or 5/4 boards (1.375 thick).
You could make beams.  I mill cherry beams 1/2 inch oversize and plane them later.  I mill cherry live edge branches 1 inch oversize as they will move more drying.
You could cut slabs 1.75, or 2.25 thick without removing the sapwood (for table tops later).
Often Cherry will have curl - curly grain, which is really nice.  You're likely to have some in that pile.
Offline Resonator
Re: Black Cherry
« Reply #11 on: September 10, 2019, 09:23:53 PM »
x2 what Mr. YellowHammer said. (He knows way more about lumber making than I do). smiley_thumbsup
I wouldn't stack green lumber in a green house unless its converted into a solar kiln. The other thing I'll add is after drying and planing, I spread the boards out inside a building. After a while the top board face gets more light and air, and gains a much richer, darker reddish color than the bottom face. This is the side I present when selling. $ ;D $
Offline Chuck White
  • Sawing Mobile since 2005
Re: Black Cherry
« Reply #12 on: September 11, 2019, 06:24:36 AM »
Good ventilation and no sun are key to storing and drying lumber!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Re: Black Cherry
« Reply #13 on: September 11, 2019, 07:54:15 AM »
How large of a shed will it take to dry 1500-2000 bf?  Would it be ok in my haymow, or should it be outside?
Re: Black Cherry
« Reply #14 on: September 11, 2019, 08:10:00 AM »
<br
I never seriously thought about getting into wood working, but so many ideas.
Re: Black Cherry
« Reply #15 on: September 11, 2019, 08:17:20 AM »
What do you do with cherry beams?
I have seen oak beams move in many directions after several years in a house.
Re: Black Cherry
« Reply #16 on: September 11, 2019, 08:40:18 AM »
    To help visualize 1,000 bf think of a 5X10 utility trailer stacked tight 20" high or 20 rows/layers of 1" boards. So if you have 2,000 bf you'd have 2 trailer loads. Double the height when you add 1" stickers between the rows. Less height if 8/4 lumber.
   I find people can visualize a utility trailer load of wood easier than any other way.
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
Re: Black Cherry
« Reply #17 on: September 11, 2019, 10:53:07 AM »
Pete and Jesse,
Generally, a stickered stack of 8', 4/4 boards, with layers 4' deep; 1000 bf will be about 5' tall.  Add your foundation height.  And at 16" spacing, you'll need about 230 stickers.
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Offline moodnacreek
  • Sawin by the notches
Re: Black Cherry
« Reply #18 on: September 11, 2019, 07:14:31 PM »
Is this woodmiser language?  I have been sawing since 1980 and don't understand this advise.
Re: Black Cherry
« Reply #19 on: September 11, 2019, 08:39:25 PM »
   Sounded clear to me and certainly what I try to do.I understood it as Pith check/heart check being the normal crack found in many if not most hardwoods and certainly in cherry and by placing the cant so you are sawing parallel when sawing through the cant to make finished boards the boards will not have the crack in them while if the crack is vertical it will show up in every board.
   BYW - I bet you have done this for years but maybe called it by different terms.
Need Black Cherry
Started by urbanlumberinc on Wanted
Last post July 26, 2006, 11:55:50 AM
by Wyatt
black cherry ?
Started by pitsaw on Sawmills and Milling
Last post April 14, 2011, 07:35:49 AM
by WDH
Pin and Black Cherry
Started by thecfarm on Forestry and Logging
Last post January 24, 2008, 11:23:49 AM
by roger 4400
black cherry
Started by Curtis Koth on Forestry and Logging
Last post December 16, 2002, 08:29:52 AM
by OneWithWood
