Author Topic: Using the Woodmizer LT 40 log turning winch. Short Video  (Read 613 times)
Offline richhiway
  • Rich
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Using the Woodmizer LT 40 log turning winch. Short Video
« Reply #1 on: September 11, 2019, 08:51:02 PM »
   Your videos are real nice and you are a hardworker IMHO but you sure do make me appreciate my hydraulics every time I watch you.
Online charles mann
« Reply #2 on: September 12, 2019, 01:28:50 AM »
aint that a cat's meow.
@WV Sawmiller just wait till my mill is built and the first few vids hit. you hydraulic owners will cry from sorrows or laughter. not sure which, probably laughter.
Temple, Tx
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« Reply #3 on: September 12, 2019, 07:11:18 AM »
I'm curious .... why the spring and chain on the log-dog?  I have similar dogs on my Champion mill and they've never come loose in twelve years of use.
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Offline richhiway
  • Rich
« Reply #4 on: September 12, 2019, 03:54:27 PM »
I didn't give it any thought, just holds tension on it. I notice sometimes it would stay with out the spring.
Woodmizer LT 40
Stihl Chainsaws
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #5 on: September 12, 2019, 06:34:20 PM »
Agree with richhiway on this one!
When I first started sawing, I used my FIL's LT40G18 Manual mill, and sometimes I used the chain and sometimes not!
I've found that if I had a lot of the log above the top of the clamp, that once in a while due to the vibration the clamp would vibrate loose and a lot can happen when the clamp moves even a little!  ::)
That happened once, then I used the chain all the time!  ;)
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #6 on: September 12, 2019, 06:57:16 PM »
x2  I use the spring chain to hold the log clamp in place, its especially needed when edging boards.
Offline richhiway
  • Rich
« Reply #7 on: September 13, 2019, 02:58:29 PM »
Thanks, Howard.
The manual would be a little easier with a helper. Working alone you do a lot of walking back and forth. When I retire from my real job I will probably upgrade to hydraulics if I can make a few bucks cutting. You really need them if you cut lumber for others.
Have a good weekend,
Rich
Woodmizer LT 40
Stihl Chainsaws
« Reply #8 on: September 13, 2019, 04:18:10 PM »
Rich,
  One thing I really miss when I see you sawing is my loading arms which I use religiously to stage my flitches and such for further sawing/edging and such. I don't see if you use them or not but a pair of saw horses for un-edged flitches look like they would sure be handy. Below is a simple design I use to make them. It is also a good use for short 2X4's that won't make full length due to flare and such. I use scrap 4x4 pieces for the side and end stretchers instead of 2X4 and they work fine too..
Offline Chuck White
« Reply #9 on: September 14, 2019, 01:41:48 PM »
Another idea for holding your flitches for edging later would be to raise the ends of your loading ramps and put a block under them to hold them around level!
Much easier than picking the flitches up off the ground or almost to the bottom of the ramps!
Been there, done that, just sayin'!  ;)
~Chuck~
Offline richhiway
  • Rich
« Reply #10 on: September 17, 2019, 06:38:22 PM »
Thanks I have the horses on the operator side. I put the slab wood on the loader forks. I am to old to be bending over!
Woodmizer LT 40
Stihl Chainsaws
One wire short of turning it on
Started by brdmkr on Drying and Processing
Last post April 02, 2009, 11:39:23 AM
by brdmkr
Log rafting ( with short video )
Started by Quebecnewf on Sawmills and Milling
Last post July 25, 2018, 05:11:54 AM
by Quebecnewf
need help posting a short video
Started by Coffee_Creek on General Board
Last post May 07, 2016, 09:26:29 PM
by Mooseherder
I made a short video of me sawing
Started by lyle niemi on Sawmills and Milling
Last post September 30, 2014, 04:55:38 AM
by ozarkgem
