Author Topic: Wood type?  (Read 555 times)
Offline Arctiva
Wood type?
« on: October 13, 2019, 09:51:03 AM »
So I'm new to burning wood last year and dont know my wood yet anyone know what species this is? I can get a few trailer loads of it. I'm in Wisconsin if that matters
Offline SwampDonkey
  • Large Tooth
Re: Wood type?
« Reply #1 on: October 13, 2019, 10:02:53 AM »
Is it light? Or a bit hefty. The stringy fibre could be basswood (light wood). If it is hefty stuff than it could be ash. Lots of soil conservation land planted in ash in North Dakota, maybe down your way to. They don't have the ash borer yet in some parts of ND at least.
Move'n on.
Online doc henderson
Re: Wood type?
« Reply #2 on: October 13, 2019, 10:19:31 AM »
It looks like a hardwood but a few more pics would help me.  other may know just from the bark and fibers.  If it looses its leaves it is by def. a hardwood.  bald cypress is an exception.  you can burn any kind of wood.  some have more density so provide more heat per unit of volume.  the less dense hardwoods (cottonwood)provide about 18 million BTUs per cord where Hedge provides 32 million BTUs per cord.  in the middle is oak, mulberry, and others, are in the range of 25 to 27 million BTUs per cord.  by dry weight, all wood including bark provides the same BTUs per unit weight.  so a less dense wood, including soft woods, will require more volume of wood, therefore more frequent loading of any wood heater.  In the north, softwoods are more plentiful so that is burned and does fine.  shorter summer make the hardwoods not grow much since they are dormant in the winter (loose leaves and have annual growth rings).  when you burn wood, you are boilng the remaining water and burning the carbon in the wood and some other volatile compounds such as pitch.  there are other qualities such as amount of coals produced.  in a good stove the air is regulated to control temp. and potentially extend the burn time.  I always burn and get a good fire and coals going.  for the night, I fill to the brim with wood, let the fire get going well, then shut down the air and have good coals to add wood to in the am.  So,  the answer is, if you need wood and have found a free or inexpensive supply, go for it.  surly someone on the supply side can help you ID the wood so you can look up the qualities of that species.  Others here will chime in and can help.  as you burn wood for years you will become more particular about what you burn, but it is still limited by supply.  In Alaska it is almost all soft wood species.  as it is in Scottsbluff, Ne.  I love burning Catalpa cause it smells good, but it pops, does not burn long, and leaves few coals.  Elm is an underrated wood for woodwork.  for firewood,  It seems to take longer to season and is nearly imposable to split by hand, but has about 25 million BTU per cord. lots of charts for firewood and qualities by species.  good luck.
Offline Arctiva
Re: Wood type?
« Reply #3 on: October 13, 2019, 10:22:46 AM »
I've kinda learned ash or at least the kind I have on my property as I have some at my place that are dead and picked up 3 loads last week of cut down ash.
Re: Wood type?
« Reply #4 on: October 13, 2019, 10:31:43 AM »
this looks fresh cut, so will need to season (dry) a year, unless standing dead or cut down a few years ago.  congrats on your good fortune
Wood Heating | Forestry | USU
Offline Arctiva
Re: Wood type?
« Reply #5 on: October 13, 2019, 11:17:28 AM »
It is fresh cut working on next years wood. Am taking loads of Ash and there a bunch of this kind. I think its cotton wood but wasnt sure.
Last summer I passed on some walnut cause it looked like some willow I cut up and someone else took it. Didnt wanna make that mistake again lol
Offline Arctiva
Re: Wood type?
« Reply #6 on: October 13, 2019, 11:23:46 AM »
Feels like a soft hardwood but IDK
Offline Arctiva
Re: Wood type?
« Reply #7 on: October 13, 2019, 11:27:03 AM »
Probably do 3 loads today on top of the 3  last weekend. Mostly Ash some maple and whatever mystery wood is lol
Re: Wood type?
« Reply #8 on: October 13, 2019, 12:09:34 PM »
If you want to be crazy about it, cut a 1 inch cube and oven dry it, and weigh it.  can calculate the BTUs and also get an idea of species based on density.    cottonwood can be very heavy green as it can be over 100% moisture content.  the bark is consistent, any leaves around by chance?  I cut and split a lot of cottonwood for my parents with a fireplace.  My dad loved to put another log on the fire every half and hour.  got him out of the chair.  If they went to bed, fire was out in an hours or so.  As it became known that I had wood, friends would call my wife to see if they could have some.  If for a firepit or fireplace, they got cottonwood, not the seasoned Mulberry.
Offline SwampDonkey
  • Large Tooth
Re: Wood type?
« Reply #9 on: October 13, 2019, 12:57:54 PM »
Could be. I burn anything here. All makes heat. I'm burning lots of aspen and balm this year, besides fir and maple and birch. I thin the woods and cut down the older stuff that is about to die , hard leaners and make sure the ant galleries are left on the ground. :D
Move'n on.
Offline Arctiva
Re: Wood type?
« Reply #10 on: October 13, 2019, 01:04:51 PM »
No leaves my city cut it and disposes the leaves and limbs at another location and drops off the big stuff at another location.
I took a few pieces just because but why bother when a good wood like Ash is available? It doesnt have a tight grain pattern like the Ash does. If I was desperate id take it all
Re: Wood type?
« Reply #11 on: October 13, 2019, 01:49:02 PM »
i totally agree with that!!! 8)
Offline Southside
Re: Wood type?
« Reply #12 on: October 13, 2019, 02:05:15 PM »
That thick bark makes me say cotton wood over ash.
Offline LeeB
Re: Wood type?
« Reply #13 on: October 13, 2019, 08:29:09 PM »
Willow maybe?
Offline lxskllr
  • dummy with saw
Re: Wood type?
« Reply #14 on: October 13, 2019, 09:23:29 PM »
How about sassafras? That bark looks really familiar to me, but I can't quite put my finger on it.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Wood type?
« Reply #15 on: October 14, 2019, 07:32:45 AM »
The wood appears to be diffuse porous.  Sassafras is ring porous.  Willow and cottonwood are diffuse porous.  Could definitely be willow or cottonwood.  Might also be basswood.
Offline kantuckid
Re: Wood type?
« Reply #16 on: November 28, 2019, 07:22:50 AM »
Willow if light enough, that's my 1st guess- it was used for prosthesis before plastics kicked in. Not cottonwood or basswood IMO.
What type of wood is it?
Started by magic on Chainsaws
Last post March 12, 2006, 06:02:41 AM
by SwampDonkey
question
Can anyone tell me what type of wood this is?
Started by hotelcali4nia1 on Sawmills and Milling
Last post January 09, 2009, 06:21:55 PM
by rebocardo
What type of wood
Started by vfauto on Sawmills and Milling
Last post June 19, 2013, 08:26:47 AM
by Okrafarmer
What type of wood?
Started by Mtbehm on Tree, Plant and Wood I.D.
Last post November 17, 2018, 10:58:08 PM
by Southside
