Author Topic: Pro Sawyer Network  (Read 1044 times)
Offline LeeB
Pro Sawyer Network
« on: October 31, 2019, 11:45:24 PM »
Anybody know why the sign up for the Pro Sawyer Network is no longer functional?
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Pro Sawyer Network
« Reply #1 on: November 02, 2019, 08:43:45 PM »
   First I'd heard of it. Probably a temporary issue while they work on it. I bet @CWarner has the answer.
Offline CWarner
  • Board Moderator
  • Wood-Mizer Public Relations Representative
« Reply #2 on: November 04, 2019, 07:30:39 AM »
Hi LeeB,
We are in the process of updating the Pro Sawyer Network and unfortunately the sign-up form is unavailable at the moment. The network and public listing is still active.
You are welcome to fill out the Pro Sawyer Application HERE and send to pro@woodmizer.com and we will get you set up with the network.
Thanks!
Offline LeeB
« Reply #3 on: November 04, 2019, 07:58:50 AM »
Thanks. I'll send it in.
Offline SAWINGALASKA
« Reply #4 on: December 23, 2019, 04:01:21 AM »
Hey, I think I will send an email to check on this also. I have applied a couple times, and haven't heard anything back this year. I will see if the email inquiry helps out. I am glad I saw this before posting the same question. Time to saw some frozen logs!
Offline LeeB
« Reply #5 on: December 23, 2019, 12:48:13 PM »
The link is working now. I submitted my app the other day.
« Reply #6 on: February 07, 2020, 04:14:52 PM »
I have sent 3 emails to that address with no reply. Anyone have another contact?
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #7 on: February 12, 2020, 07:26:59 AM »
Send it directly to cwarner@woodmizer.com
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Pro Sawyer Network, Thanks Forestry Forum and Woodmizer!
Started by fishpharmer on General Board
Last post January 03, 2013, 06:52:07 AM
by fishpharmer
WDH, CUSTOM SAWYER SAWYER & YELLOW HAMMER....a day in the SHOP!
Started by POSTON WIDEHEAD on General Board
Last post May 14, 2018, 11:08:27 PM
by YellowHammer
Network Upgrade
Started by Jeff on Technical Support Topics
Last post April 04, 2014, 07:02:22 PM
by Warbird
network problems
Last post January 20, 2005, 11:15:35 PM
by Roxie
