ms 661
Started by 421Altered, January 01, 2020, 11:14:31 AM
421Altered
How much mix will a ms 661 burn in a 8 hour work day in Oak?  Using a 36 inch bar with a full compliment chain.  I know that it depends on a lot of various factors, but, just need a ball park figure.  Thanks.
lxskllr
I was using a bit less than a tank per cut milling 11'x28" ash. If I were to take a stab at it, a 2.5G can should be sufficient for a typical work day cutting wood(not milling).
421Altered
lxskllr,  That's the stab I needed, thanks!!
