Stihl 024 Super Piston
Started by ZeroJunk, January 22, 2020, 12:27:43 PM
ZeroJunk
I guess I slept through this one. I have one torn down and the cylinder cleaned up.  Just want to make sure that it uses the same piston as an 024 . IPL only shows one, but those things are not 100% reliable.
Mad Professor
I don't think so, stoke is different and my IPL list two pistons/cylinders.  And two cranks.
I think you can put a 44mm/44.7mm 026 P/C on a 024S, they have same stroke, I think if I recall.....
That will be 2mm bigger bore ;D
