Author Topic: woodmizer lx55  (Read 2586 times)
Offline tlbrooks
woodmizer lx55
« on: January 31, 2020, 08:07:16 PM »
I know the  lx55 is a newer mill but does anyone have one that can give any advice on the mill?
Offline KenMac
  • I'm new, but don't feel so new!
Re: woodmizer lx55
« Reply #1 on: February 01, 2020, 11:09:00 AM »
I'm no Woodmizer expert by any means, but you might check out "Outdoors with the Morgans" on Youtube. They have an LX150 and have many videos of it. Hope this helps.  :-\
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB
Offline tlbrooks
Re: woodmizer lx55
« Reply #2 on: February 02, 2020, 12:08:48 AM »
ill check it out. I ordered a lx55 while they were on sale .
Offline samandothers
Re: woodmizer lx55
« Reply #3 on: February 02, 2020, 07:47:51 AM »
Hope you enjoy the mill!  Where from in Va?  We have some land we enjoy not too far south and west of Roanoke.
Offline tlbrooks
Re: woodmizer lx55
« Reply #4 on: February 03, 2020, 12:48:18 AM »
extreme western part of va. cant wait to get it but its a few weeks wait they said.
Re: woodmizer lx55
« Reply #5 on: February 03, 2020, 08:39:55 PM »
Congrats!  Carolina Woodmizer?
Offline tlbrooks
Re: woodmizer lx55
« Reply #6 on: February 03, 2020, 11:42:23 PM »
yes nc woodmizer . does anybody have a good idea on mounting the mill to keep it portable? maybe a 4x6 timber or 2x3 or 2x4 x 3/16 metal tube frame under it. I wanted to be able to slid it in my trailer to haul it.
Offline woodnut
Re: woodmizer lx55
« Reply #7 on: March 24, 2020, 11:14:23 PM »
tlbrooks, I picked up a LX-55 in Indianapolis on March 5th and started to piece it together in Fort
Wayne at my Fathers home where the logs were at. It took us days to put it together I'm not proud to say. Some of the printed instructions were not clear to us and were slowing us down. I'm real happy with the way it is cutting wood. We cut 10 or so walnut logs 12 to 20 inches wide and 8 feet long. It took a few blades though. But to answer your question about the portability of the mill. I will be putting some runners on the bed to make it more stable for moving because when we dragged it on the feet with some wood pieces everything in the back half loosen up and we had to realign level and tighten stuff. I hope this helps.
Offline Patrick NC
Re: woodmizer lx55
« Reply #8 on: March 25, 2020, 04:33:20 AM »
I have a timbery m100 which is a very similar mill to the lx55. Track is almost identical.  I reinforced an old boat trailer and mounted it. I've had some 22" yellow pine on it and it is very solid.
Offline tlbrooks
Re: woodmizer lx55
« Reply #9 on: March 25, 2020, 01:11:35 PM »
I got mine together  with my son helping in about 10 or 12 hours over a couple of days and finished yesterday. work weather yard mowing its hard to find enough time to do it all. im searching for a cheap trailer now.
Offline woodnut
Re: woodmizer lx55
« Reply #10 on: April 10, 2020, 03:44:21 PM »
That is a nice set-up Patrick. Thanks for the post!  Enjoy the mills Patrick and tlbrooks!
Offline Billmaz
Re: woodmizer lx55
« Reply #11 on: June 18, 2020, 10:25:37 PM »
Took me at least 10 hours. Directions were not good. Missing parts had to make 2 holes bigger. Not portable at all. I got the electric but apparently my electric cant handle it. Do you have an electric?
Offline tlbrooks
Re: woodmizer lx55
« Reply #12 on: June 19, 2020, 07:22:08 PM »
mine is 14 hp gas. woodmizer was very helpful on a few questions i had about the head stop bolts and i mention i was 2 or 3 bolts short the guy said ill send you 5 bolt  with nuts and a day or two they was in my mailbox. mine cuts excellent lumber but im still learning about it. i need to try different blades to see what works best for me. if i was buying a small msanual mill tommorrow it would be a lx55.
Offline Patrick NC
Re: woodmizer lx55
« Reply #13 on: June 19, 2020, 07:45:42 PM »
I've also got 14 hp and I spent quite a bit of time and money trying to find the right blade. Had pretty good results with wm 9 degree double hards, but have finally settled on kasco 4 degree. The first one I used was the straightest cut I ever made. A lot of people on here told me that 4 degree was best for lower hp mills, but I was hard headed and had to try a bunch of others before I got the 4s. They work really good for me in both hard and softwood. Hope this helps.
Offline tlbrooks
Re: woodmizer lx55
« Reply #14 on: June 20, 2020, 07:15:07 PM »
i was going to order some of the double hard and try them. do they have them in 4 degree? i saw mainly oak and would like to cut some walnut but i need some more saw time before i cut some 26 inch walnut i have. whats the price of the kasco blades?
Offline Patrick NC
Re: woodmizer lx55
« Reply #15 on: June 21, 2020, 08:55:32 AM »
I can't remember the exact price on the kasco blades but I think with shipping they were less than the wm blades before shipping. I've never tried the wm 4 double hards, but I've been thinking about trying one.
woodmizer lx55 update
Started by tlbrooks on Sawmills and Milling
Last post April 19, 2020, 08:47:15 AM
by tlbrooks
exclamation
Woodmizer LX55 Electric motor
Started by Billmaz on Sawmills and Milling
Last post August 01, 2020, 04:59:06 PM
by Billmaz
LX55
Started by francismilker on Sawmills and Milling
Last post October 31, 2019, 07:28:57 PM
by red
experience with the Wood-Mizer LX55?
Started by Spindrifter on Sawmills and Milling
Last post November 22, 2019, 06:01:54 AM
by ladylake
