Author Topic: Foley Belsaw M14  (Read 330 times)
Offline dthreatt11
Foley Belsaw M14
« on: February 10, 2020, 11:19:40 AM »
Just purchased a Foley Belsaw M14 that was never assembled by original owner. Seems like we have everything except the cable to drive the carriage. Anyone know the diameter and a guess at the length needed. Thanks in advance.
Offline moodnacreek
  • Sawin by the notches
Re: Foley Belsaw M14
« Reply #1 on: February 10, 2020, 12:26:48 PM »
1/4 to 5/16". I guess you could pull a string or wire to mock up the cable.
I have also forgotten how many wraps around the drum but 4 should work.
Offline moodnacreek
« Reply #2 on: February 10, 2020, 12:45:38 PM »
If you go to my gallery you can view the cable drum I made years ago on a bellsaw. The set up that comes on that mill is really not right. The A belt running off the center of the mandrel hardly works. It needs to be a B belt and mounted outside the way timbers.
Offline Brian_Rhoad
« Reply #3 on: February 10, 2020, 12:47:35 PM »
The Belsaw manual shows 1/4" x 66'.
You can download the manual here: http://vintagemachinery.org/pubs/detail.aspx?id=1050
Offline dthreatt11
« Reply #4 on: February 10, 2020, 02:54:57 PM »
Thanks man. I actually have that manual printed out but I guess I was overlooking it in the list. I see it now. Thanks again. I will prolly have many more questions
thumbup
foley belsaw
Started by Buck Sawyer on Wanted
Last post July 25, 2011, 04:19:02 PM
by HOGFARMER
foley belsaw
Started by beav39 on General Board
Last post March 29, 2009, 08:40:28 PM
by rpg52
Foley-Belsaw M-14
Started by SimpleLife on Sawmills and Milling
Last post September 01, 2018, 08:47:46 PM
by bandmiller2
Foley belsaw m14
Started by michiganmilkman on Wanted
Last post February 14, 2016, 01:47:10 PM
by thecol
