Author Topic: Replace Kohler 440 on frontier or Norwood  (Read 457 times)
Offline Wolfgang Rother
« on: February 11, 2020, 04:05:20 PM »
 Which engine does fit or which stronger one can I use?
Some of u do have some experience with that?
Thx Wolfgang
Offline sawguy21
Re: Replace Kohler 440 on frontier or Norwood
« Reply #1 on: February 11, 2020, 08:11:28 PM »
That model number doesn't sound right, a Kohler 440 to me is an old snowmobile engine.
« Reply #2 on: February 12, 2020, 09:40:28 AM »
Kohler command pro ch440 and 420cc
« Reply #3 on: February 12, 2020, 09:41:13 AM »
429cc , sry
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #4 on: February 12, 2020, 10:41:32 AM »
Kohler (and most manufacturers) lists the shaft diameter, shaft length, shaft location and mounting hole dimensions for its engines on the website.  You could check if the dimensions for a higher cc engine match your current engine.  It's just a guess that above 20 hp the dimensions change.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline armyturner
« Reply #5 on: February 14, 2020, 10:18:18 AM »
My uncle replaced the factory engine in his boardwalk with the 22hp predator from harbor freight. It's been running strong for several years and cost about half of a name brand in the same hp rating.
« Reply #6 on: February 16, 2020, 02:59:09 PM »
What's about a diesel... How many hp do I need then ???
Much more torque....
Do have some of u some ideas?
Norwood Frontier OS 23, 27, 31
Started by adirondacker on Sawmills and Milling
Last post August 14, 2019, 11:47:17 PM
by DavidLovesUSA
Norwood's Frontier line up of OS 23,27,31
Last post August 15, 2019, 05:58:24 AM
by thecfarm
moved
MOVED: Norwood Frontier OS 23, 27, 31
Started by chet on Forestry and Logging
Last post July 15, 2019, 12:11:31 AM
by chet
Norwood Frontier sawmills
Last post August 06, 2019, 07:29:03 AM
by Dana Stanley
