Author Topic: 1972 664B Clark  (Read 508 times)
Offline vonmainestay
1972 664B Clark
« on: February 20, 2020, 07:05:09 AM »
I am a newbie to this group and have a 664B that has been loosing power for drive and hydraulic winch. Steering and blade are functioning as it should. I don't get good high RPMs when attempting forward or reverse or using the winch. Where should I start? All fluids are at adequate levels as well.
Any advice for a novice?
Offline air1514
Re: 1972 664B Clark
« Reply #1 on: February 20, 2020, 11:11:14 AM »
Does it have a Detroit engine?   Sounds like the engine needs tuned.
Re: 1972 664B Clark
« Reply #2 on: February 20, 2020, 11:51:25 AM »
It does have a Detroit. What is strange is with no load on the hydraulics the RPMs are fine and the blade and steering have plenty of operating pressure it seems.
I was wondering if a hydraulic filter for the drive and winch could be the issue?
Offline kiko
Re: 1972 664B Clark
« Reply #3 on: February 20, 2020, 10:31:29 PM »
Sounds like you have an issue with the transmission pressure. I assume it has a Clark winch. If so it operates off of transmission pressure and shares the oil with transmission.  We used to add transmission fluid at the winch because it was much easier than under that flip up floor board. Those were D and F models. Change the transmission filter first then check transmission pump pressure.
Re: 1972 664B Clark
« Reply #4 on: February 24, 2020, 06:51:14 AM »
Thanks very much Kiko. I will certainly do that and see what kind of pressure I can get.
Offline kiko
Re: 1972 664B Clark
« Reply #5 on: February 24, 2020, 08:40:58 AM »
Transmission pressure should be around 300psi
Will a 664c Clark Tranny fit a 664b clark ranger skidder?
Started by delimberboy on Forestry and Logging
Last post December 22, 2015, 01:23:05 PM
by oldseabee
Clark ranger 664b
Started by Jet fuel on Forestry and Logging
Last post June 10, 2018, 12:52:33 PM
by Jet fuel
70s Clark 664B issue
Started by taurus on Forestry and Logging
Last post September 07, 2018, 01:29:58 PM
by Haleiwa
Do Clark 664c and 664b use the same planetary's
Started by stobbe on Forestry and Logging
Last post March 24, 2017, 09:40:45 AM
by air1514
