Author Topic: Timberjack 240 maintenance questions  (Read 397 times)
Offline Putnamqdm@yahoo
« on: February 24, 2020, 07:12:54 PM »
I have a TJ 240 GAEAN with a 453 Detroit and Automatic transmission. Can anyone tell me what type trans fluid  it takes (New process Auto Tranny) also how to check level does it have to be warm and in Neutral? does it fill from dip stick?
Anyone know approximate weight of the skidder wheel size  23.1-26 have to remove it not sure if my 26HP tractor can lift for install.
What type of Hydraulic Fluid does it take?
Offline tj240
  • partner in Williams timber harvesting
Re: Timberjack 240 maintenance questions
« Reply #1 on: March 03, 2020, 04:59:35 PM »
I would say standard 303 for hyd, trans should be what you would run in a allison.  Is it for sale? A friend is looking to update his older 230.
work with my father[jwilly] and my son. we have a 240 tj 160 barko[old] works great three generations working together
Offline tj240
« Reply #2 on: March 03, 2020, 07:50:02 PM »
I'm guessing you are in putnam ny.  Andy Swinton is in lake george, he is a TJ wizard. PM me and I will give you his number, if you are in putnam
Home Central Air Con Maintenance Questions
Started by lowpolyjoe on General Board
Last post July 15, 2015, 11:08:44 AM
by yukon cornelius
Wood boiler maintenance questions
Started by Engineer on General Board
Last post March 14, 2008, 08:36:28 PM
by thecfarm
Lucas Mill maintenance questions...
Started by chainsaw_louie on Sawmills and Milling
Last post January 01, 2012, 08:47:10 PM
by chainsaw_louie
Questions on guide bars - wear, maintenance and replacement?
Started by Great Big on Chainsaws
Last post February 22, 2009, 08:55:07 PM
by ErikC
