Author Topic: Buck saw sprocket  (Read 287 times)
Offline Justalogger
Buck saw sprocket
« on: March 14, 2020, 04:11:50 PM »
I got a old Hudson buck saw and need a new sprocket mine is a 9 tooth 1 1/4 bore and 1” thick. I have seen some online but only 5/8 thick anyone know where to maybe find one 1” thick ? Just trying to keep from maybe modifying  things and keep it simple thanks.
Offline Hilltop366
Re: Buck saw sprocket
« Reply #1 on: March 14, 2020, 05:18:12 PM »
If you can't find one these guys say they can custom make one to your specs.
https://www.6kproducts.com/chain_saw_sprocket.html
Offline Justalogger
« Reply #2 on: March 14, 2020, 07:13:39 PM »
Thank you bud...
Offline mills
« Reply #3 on: March 15, 2020, 05:05:18 AM »
I just went through my old, old CRS with new bearings, and sprocket. The sprocket is a common size, but the bore is only 1". The younger guys at the saw shop couldn't find it on the parts sheet, but the oldest guy in the shop found it when he came in the next morning. My next step was to have a machine shop friend make me one. He didn't think it would to difficult.
Offline Hilltop366
« Reply #4 on: March 15, 2020, 08:43:53 AM »
Your welcome.
Offline Skeans1
« Reply #5 on: March 15, 2020, 10:48:06 AM »
Have you looked in the harvester handbook? Is your sprocket right now the replaceable pin style? It shows a the harvester lok by Oregon for that shaft diameter. Gem bar and chain also shows they build a sprocket for that shaft size and tooth count.
Offline Justalogger
« Reply #6 on: March 15, 2020, 12:04:52 PM »
It just slides on the shaft and is held on with a 5/16 key way then a washer and bolt on the end to keep it on.
Buck Knives & Buck Knife Co. Warranty
Started by Shotgun on General Board
Last post November 22, 2011, 07:14:11 PM
by Logjam
3/8 lo pro rim sprocket
Started by Caloren on Chainsaws
Last post June 22, 2015, 10:48:46 PM
by joe_indi
Rim Sprocket for MS 460
Started by Good Feller on Chainsaws
Last post July 28, 2008, 01:13:30 AM
by Southernlogger007
385 with 8 sprocket...
Started by Ever Green on Chainsaws
Last post March 26, 2006, 10:40:30 AM
by Rob
