make your own hardware for bifold kiln doors?
Started by farmfromkansas, April 25, 2020, 08:23:26 AM
farmfromkansas
  Was searching the forum yesterday for hardware for bifold kiln doors, got 2 of mine hung yesterday, found Danny's pic of his kiln, 7 door hinges on each door.  Think I will add some more.  But need some bolts for the first door, and then just plan to use a 2x4 and bolts to lock the center.  Too wet this morning to get into my junk iron pile, wondering what others have done.
farmfromkansas
Went to Menards Saturday, found what i needed, 11% off.
YellowHammer
I would highly recommend a cam door closing latch system, like on a trailer, to shut the door with.  It applies pressure to the door seals to maintain a tight fit.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
GeneWengert-WoodDoc
Safety practices would be to have at least one door that can be opened from the inside.
