A Wood-Mizer LT40 sawing video. Not to boring!
Started by richhiway, May 02, 2020, 10:33:23 AM
richhiway
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Ford 340 Backhoe
trimguy
Thanks for another video! I ordered an Lt40 hd 6 months ago, well calendar says it was only 2 weeks ago :D. I pick it up May 15th 8). Do you leave the blade engaged so the simple set wont reset ? I know they will go over all this with me when I pick it up. Just curious ?
YellowHammer
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
richhiway
Quote from: trimguy on May 02, 2020, 06:21:32 PM
The simple set works with the blade engaged or not. It will always find it's way to the next cut no matter how much you raise it on the return. It is just faster for me.
Good luck with the new mill, you are going to love it.
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
