Dynamic Green Products Inc.
Author Topic: sauna door for kiln access door?  (Read 265 times)
Offline forrestM
« on: May 14, 2020, 12:06:05 PM »
What kind of door should I use for an access door for my kiln chamber? I spoke with the friend the other day and he just finished building a sauna for someone and he purchased a sauna door. seems like they would be able to withstand the moisture and heat, but i am not sure. Has anyone ever tried that? If not, what kind of doors do you use? I am thinking of a 24" wide door, or narrower, if I can get one. Do you add insulation to the interior of your doors?
thanks,
forrest
Offline busenitzcww
Re: sauna door for kiln access door?
« Reply #1 on: May 16, 2020, 12:24:00 AM »
 I just built mine identical to my wall except I used 1/4 on the inside instead of 1/2 so Id have room for my seals on the inside. Clearance is a little tricky with the door being that thick.
Door for 1984 or 85 Timberjack 240A (DOOR FOUND)
Started by Rob-IL on Wanted
Last post August 24, 2010, 05:56:07 PM
by Rob-IL
Kiln door?
Started by WoodChucker on Drying and Processing
Last post July 21, 2004, 06:11:09 PM
by WoodChucker
Kiln door
Started by logbyr on Drying and Processing
Last post June 09, 2020, 11:15:03 PM
by logbyr
Kiln door for Nyle
Started by brdmkr on Drying and Processing
Last post August 30, 2008, 11:41:37 PM
by brdmkr
