Dynamic Green Products Inc.
Author Topic: New guy that cant figure out a tree  (Read 550 times)
Offline Jmsvickers
  • Member*
« on: May 17, 2020, 06:19:50 AM »
Hi all, I'm new to the forum and live in southern Maryland,  I have been clearing some land and taking trees down from around the house to get some sun and grass to grow (hopefully). One tree I cut I cant figure out what it is, and i have seen more around that have similar leaves but the bark varies alot in texture and color. Any how here is a photo of the one I cut. Oh and disregard the odd cut of the stump, I had to get " inventive" as it got hung up and we had limited options.
Any info would be appreciated, I'm more curious than anything. Thank you!
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: New guy that cant figure out a tree
« Reply #1 on: May 17, 2020, 07:13:34 AM »
Blackgum.  Nyssa sylvatica.
Virginia Tech Dendrology Fact Sheet
Offline mike_belben
  • Pulp Friction
« Reply #2 on: May 28, 2020, 10:23:06 PM »
Let the stump sprout and youll have deer mowing it down.
Revelation 3:20
Offline Wudman
  • Eat, drink, and be merry before you go on quota!
« Reply #3 on: May 29, 2020, 08:46:22 AM »
You will really love it when you go to grub that stump.  It has a taproot about the same diameter headed to China.  They don't come up.....you just shear them off below ground level.
Wudman
You may tear down statues and burn buildings but you cant kill the spirit of patriots and when theyve had enough this madness will end.
Charlie Daniels
July 4, 2020 (2 days before his death)
Offline mike_belben
  • Pulp Friction
« Reply #4 on: May 30, 2020, 08:58:11 AM »
Question for you @Wudman ..
Will a black gum grow over shallow rock where it cant send a big tap root down?  Does the taproot limit the growth of the trunk or crown?
Theyre prolific here in middle TN but i live on clay over sandstone ledge. Sometimes its 3inches, sometimes 4 or 6 feet.  An indicator tree would be really handy as the oaks will LIE to you!  Very common to have a monster oak blown over with a 20ft rootball that only went down knee deep.
Revelation 3:20
Offline Wudman
« Reply #5 on: May 31, 2020, 02:34:33 PM »
It will probably do ok.  It prefers moderate to well drained clays or clay loams.  It is commonly found to about 3,000 feet of elevation on down to the coastal plain terrace.  It does not like alkaline soils, so it doesn't do well over a limestone base.  If it can get a foothold, it will probably spit rock for you.
Wudman
Charlie Daniels
Offline mike_belben
  • Pulp Friction
« Reply #6 on: May 31, 2020, 10:25:21 PM »
Ancient turned up trees are precisely where you pick the best weathered fieldstone around here actually.  The tree is usually gone but the mound and hole remain.
Revelation 3:20
Can anyone help me figure out what is going on with this tree?
Started by Blloyd1903 on Tree, Plant and Wood I.D.
Last post May 07, 2016, 12:34:06 PM
by ljohnsaw
Go Figure
Started by metalspinner on General Board
Last post August 30, 2012, 08:16:49 PM
by WDH
can you figure up ac. by using a GPS?
Started by Rod on Ask The Forester
Last post November 11, 2003, 06:00:31 PM
by Rod
question
Can't figure it out........
Started by Furby on General Board
Last post August 27, 2006, 09:27:05 PM
by Furby
