We have contest winners!
I use the Verathane version of this product and I am not sure how much difference is between the two, I suspect they are very similar. I have one nice bench that has been out in the weather all year, but not in direct sunlight and a nicer bar that lives outside but not in the sun or rain. I will try to get the one back that belongs to me and see how it has done. Mostly I find this holds up well. I gave a bench to a neighbor, it is maple and very light, so it has a yellowish patina as finished. That was left out in the rain/snow/sun since last summer and I saw it last week and it is not any darker than I recall. But I do have a question: I bought a gallon around June of 2019 and did a few good sized pieces, more than a few coats each. then I used it for a few more projects through the fall and winter, but around December I noticed it getting thick and dark and I still had just under a half gallon left. I figured it was getting too much air when I opened it frequently, so I got two new 1 qt. cans and poured it into those, but when each got down to half full, they developed thick skins and darkened more. What more, they gave a poor finish. SO I resolved to only buy them in 1 qt. cans. Well today I opened that can, which is nearly done and it too it skinned over. It's only 2 months old. Now my local source has been out of stock for over a week. I am thinking about trying the min-wax version of this product. Have any of you guys had this issue with the min-wax? Any tips on getting it to hold up in the can? I think it's important to note that I use oil based, exterior rated type, not the water based. I have not seen nor heard of good outdoor results with the water based at all. I can't tell from the can in the first post which type it is.
I use a good quality varnish
Started by Delawhere Jack on General Woodworking
Started by slider on Drying and Processing
Started by Engineer on Timber Framing/Log construction
Started by ozarkgem on General Woodworking
