Lichtenberg
Started by doc henderson, July 14, 2020, 12:06:06 AM
doc henderson
@WV Sawmiller ,  can you see if you can interview and take pics of your buddies machine and process.  I have seen video, and would like to try, but not die.  high voltage is to be respected!
WV Sawmiller
Doc,
   I just meet him at our local flea market and never been to his house which is 20-25 miles from me. I will ask him if he has a picture or try to get one of it if I'm ever there. I think his wife will be buying some basswood from me soon.
doc henderson
thanks Howard.  Maybe he would like to join the forum and school us all.   :o :o :o  :D
Larry
My Dad was a licensed electrician working in power company substations with high voltage. In the service I worked on microwave and some radar installations using high powered klystrons. Also worked around voltages where arc flash was a concern. I think I have a good working knowledge of what can happen with high voltage toys. Safety precautions need to be extreme when working with the voltages a junk microwave oven can produce. Knowledge of what kind of insulation is sufficient is paramount.  Even test equipment is suspect.  Ever seen a cheap multi-meter explode?
While I think fracking is something interesting that can be pursued with caution, I don't think the how to's should be discussed on a open forum. Some folks don't have a appreciation of the dangers of super high voltage.
Another one dies this spring.
Widow of Milton man warns of “wood fracking” dangers
doc henderson
good points Larry.  this is why I would like to learn from someone that has knowledge and not just cuhonnas.  I do not want to learn the hard way!   :o :o :o
lxskllr
" I don't think the how to's should be discussed on a open forum."
I disagree with this pretty strongly. More knowledge is always better than less knowledge, and it's up to every individual to evaluate the risks themselves. Every aspect of this forum is dedicated to activities that carry a risk of death and injury that tops OSHA's charts, and that's with professionals doing the work. Taking away information can only increase the risks.
Sedgehammer
Neon light drivers are much safer. Plus you never hold the arch when on. If set up properly IMO you set both electrodes and let go. Then switch on. Some that use the microwave transformers use the dial power ones. They start it on low and then increase the power.
Necessity is the engine of drive
doc henderson
WVs guy seems to do a good job, and not dead yet.  everything I do in life has risk.
WV Sawmiller
   He's not dead but he says he has been shocked a time or two which may explain his current mental sate - or may be he was crazy before. :D
doc henderson
maybe if he reverses the polarity, he will be sane again??  not recommended, helps to be a little off.   :D :D
Tacotodd
Just remember: Crazy, not Stupid.
Their is a BIG difference!
My friends say I'm crazy, and only those that know me say I am not stupid. Ignorant, yes. Stupid, no. Ignorance can be taught better. Stupid is forever.
Trying harder everyday.
shinnlinger
When I do if I use an old oil burner transformer.  10,000 volts but only .023 milliamps.   I have been ticked a time or two but what works great is clamping the two leads in place and stepping back and turning the power on.
All that said, it gets old and it can be overdone.
Dave
Shinnlinger
scsmith42
I have no idea what is being discussed in this thread... but I'm intrigued.  Can anyone enlighten me?
(Nevermind - I found the related threads)
Tom's 3638D Baker band mill
TimW
I met a new customer that does it.  Saw it done to a cedar board while he was dialing up the power slow.  It looks like controlled lightning moving down the board and very beautiful and mesmerizing.
They called in Frackning.
         hugs,  brandi
doc henderson
WV Sawmiller
Doc,
   The only pictures I have are of the results - not the process.
Which of you would go out and stand beneath a lone pine in the middle of a barren field during a major thunder storm?
Old Greenhorn
Now that's funny right there! And fairly accurate too! :D
caveman
We had a customer (biker chick) several years ago who bought quite a bit of wood from us.  She used to do wood burning and then got into this process along with epoxy resin.  She stayed busy making things for clients and then she moved to Utah.
The bottom photos are of a bar she did somewhere in SW Fl.  From what I've read about it, it (Tom) is a good way to get killed.  The results, assuming one survives, are pretty spectacular.
Caveman
Plus to me, some of it is overdone and ugly.  ::)
YellowHammer
We had some customers in the past do it, some got "knocked to the ground" some just quit, and some I've never seem again.  I talked to the ones who were doing it at length to determine their electrical awareness and skill level, as well as their technique.  None seemed to be using proper electrical safety precautions as they described their attempts to me.  None were using a proper remote deadman switch.  None were using proper electrical PP&E.  One said he bought his Lichtenberg set online and so it was "Safe."
There seem to be two tiers of technique an operator progress through.  A purely remote technique that can be managed relatively easily in terms of safety, and once they get bored of that, then a manual, hands on stage which is much more dangerous but gives much better results.  The manual hands on technique involves moving the electrodes across the wood piece, in effect like a lightning pen, and the operator can do some pretty amazing stuff like write names, draw lake outlines, and stencil.  However, it's by far the most dangerous and it also produces the best results.
One guy I talked to was hand holding his electrode wearing only a single set of rubber electrical protective gloves he ordered from Amazon.  He was painting electrolyte solution with one hand and holding the energized electrode in the other, burning people's names on wooden coffee cups.  I verbally laid into him in front of his wife at our shop and let them both know that they better get his last will and testament in order.
The most common response I get from our customers is they say if they "get hit" it will be no worse than an electric cattle fence.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
WV Sawmiller
   I don't do it. I take my wood to a guy who does it for me. I think he said he used the transformer out of a microwave oven. Others use transformers out of neon signs. I am told the neon sings have a much lower wattage (Amperage?).
    I saw a man at our local flea market selling jewelry boxes he had made and engraved. He said he used a low voltage kit and told me about the neon sign. He also filled his with colored epoxy to make the etching stand out more.
doc henderson
volts x amps = watts
I have considered it, but not sure who to trust to teach and build/buy a unit.  I could get pics of a pattern and just laser engrave it on wood with CO2 laser.  Lost my hard drive (computer cannot see it) after a power outage a few days back.  not good at graduation time.
YellowHammer
We had a Lichtenberg guy show up yesterday, about 30 years old, barefoot.   ::)  He brought some samples and I thought about this post.
The problem I see is what happened yesterday, that the patterns are pretty random and other than the "Oh, it looks cool" that people blurted out first, then they immediately ask "What's it supposed to be?"
I like Doc's idea, use a laser engraver to match the look while actually making a design that fits the customer and becomes a sellable product, not just a novelty.
YellowHammerisms:
