Kiln data to track
Started by TreadsActual, July 14, 2020, 10:17:06 AM
TreadsActual
Our iDry Vacutherm kiln arrives next month.
For those of you with experience operating kilns, what data are you currently tracking and what data do you wish you had tracked from the beginning?
I plan on tracking species, brdft, length of time in the kiln, starting and ending mc, time spent on low power and high power.
iDry vacutherm kiln, Leadermac six head 12" moulder, Taylor clamp carrier, 25" Grizzly planer, Hyster forklift, SawStop ICS
GeneWengert-WoodDoc
Most kiln operators also record and display on a graph the temperature and humidity many times an hour.  At least four times an hour is reasonable.
Lumber thickness is important.
You also should record the grain...mostly rift and q-sawn, etc.
You also want the daily MC of your samples to the closest 0.1% MC.  The wettest is most critical.
You also want the daily moisture content loss, compared to the published safe rate.
