Author Topic: HVAC question  (Read 368 times)
Offline Banjo picker
HVAC question
« on: July 22, 2020, 05:46:42 AM »
I know we have some hvac folks on here and I have a question.  Canít find the answer on internet so I think my odds are better here.  We have a rental that we put a new window ac in 2 years ago.  GE model number Ahs18dxl1. The compressor and fan run fine and it cools great.  Blows snowballs... well almost.  Trouble is the touch pads donít work.  Non of them.  If the main control panel is shot would it still cool?  Any inside would be appreciated.  If you know the hvac folks on here, how about please directing them to this topic.  Going to open it up this afternoon and see if anything visible shows before I start throwing parts at it.  This is a fair sized unit. Paid between 5&6 hundred for it not one of the throw away little ones.  This is one time I should have bought the extended warranty.  Tim
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
Re: HVAC question
« Reply #1 on: July 22, 2020, 08:20:22 AM »
Don't know the answer but I feel your pain!
My rental wall or window shakers give me the most problems. Mostly due to nasty people that do not keep them clean.
Between cat hair, people dander and cooking everything in grease seems like I'm constantly cleaning evaps.
The First 60 years of childhood is always the hardest.
Re: HVAC question
« Reply #2 on: July 22, 2020, 11:38:06 AM »
I took one semester of HVAC at the local junior college back in the day, but things have changed, plus I didnít learn much.  This one comes on and blows cold air ...you just canít control it.  The lady has animals, but the place is spotless and everything on the unit is clean.  Tim
Offline Larry
    • Copas Sawmill
Re: HVAC question
« Reply #3 on: July 22, 2020, 11:56:55 AM »
I have an LG in the shop with a touch pad that quick working after about a year.  The funny thing is the remote control works just fine.
I think the one I had previous to this one also had the same problem.
Might be the caused by the shop environment.
Re: HVAC question
« Reply #4 on: July 22, 2020, 02:54:28 PM »
There has been two renters in there since we put it in.... one of them must of ďmistakenlyĒ taken the remote when they moved.  Tim
Offline K-Guy
    • http://www.nyle.com/
Re: HVAC question
« Reply #5 on: July 22, 2020, 04:15:15 PM »
What you have is more of a controls problem not an HVAC one. See if you can get a wiring diagram and rewire it to a thermostat capable of cooling.  smiley_wavy
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Re: HVAC question
« Reply #6 on: July 22, 2020, 05:27:00 PM »
I am doubling down on Larryís idea.  I ordered the remote control for it today.  🙂. Gonna try that before I tear into it.  Tim
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: HVAC question
« Reply #7 on: July 23, 2020, 08:33:53 AM »
I suppose you tried completely unplugging the unit.  Sometimes it works when today's electronics get out of whack.
Re: HVAC question
« Reply #8 on: July 23, 2020, 11:00:42 AM »
Yes we tried that several times.  Thanks Tim
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: HVAC question
« Reply #9 on: July 23, 2020, 12:25:37 PM »
Well, so much for "easy".  :-X
Offline Old Greenhorn
Re: HVAC question
« Reply #10 on: July 23, 2020, 12:52:20 PM »
The touch pads on these is usually a plug in affair. Most of those do-hickeys have little plugs on them, some like a ribbon cable. If you pull the fromt panel off andcan get access to it, follow the cable and check the little plug. If that isn't it search for numbers, you might just be able to get a new touch pad cheap-ish.
 Actually it was so easy I just did it. Went to the GE support site and looked at the parts diagram. I believe the part you want is the display board, p/n WJ26X20184 about 47 bucks.
Here is the page link, hope this helps: LINK
Good luck,
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here. OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker
Compressor problems on my hvac unit...and fix
Started by Banjo picker on General Board
Last post October 03, 2015, 06:46:27 PM
by Banjo picker
Installing a gas furnace in my shop - HVAC
Started by DouginUtah on General Board
Last post October 20, 2012, 10:28:59 PM
by DouginUtah
Thoughts on insulation for a no-HVAC house.
Started by JonahAP on Timber Framing/Log construction
Last post December 22, 2019, 01:37:21 PM
by ljohnsaw
Looking for some advice/experience HVAC PLAN for Permit
Started by badger1 on Timber Framing/Log construction
Last post August 23, 2018, 09:14:09 AM
by badger1
