Sounds like to much air in the tank. Why did you put a pressure switch on it? Is that normal on a solar system. It probably has a built-in low water safety, otherwise it would be burnt up by now. my .02SE
I have some experience with one years ago. BIL had a remote cabin. Well driller drilled a new well and installed one. I installed pipe and wire to the house and set the tank and controller up. This one was set up a little different than yours as it only had a three gallon tank so the controller would bring the pump on right away. This one didn't have a low water sensor that I ever saw. This area had a lot of what we call flour sand and that pump didn't like that at all. If the pump took a few extra amps to get started it would fault out the controller. A couple of the controllers went bad in a short period of time. Within five years the pump was pulled and replaced with a normal three wire pump with a regular pressure tank and a inverter to go from his battery power to 220 AC. Make sure your tanks are empty when you check you air pressure and it should be 2-4 PSI lower than your setting on your cut in pressure on your switch. You either have a tank, switch problem or the pump is going bad and not coming on right away when the tanks are going empty. I am guessing your have two tanks because the well is low producing?
Started by Ironwood on General Board
Started by overclocking on Firewood and Wood Heating
Started by stumper on Firewood and Wood Heating
Started by Sixacresand on General Board
