Author Topic: sawmill head and log bed adjustments  (Read 429 times)
Offline WildWendi
« on: August 25, 2020, 08:37:35 PM »
Hello all,
   First time sawmill owner here! Just finished assembly on our Woodmizer LX55 and made our first cut. Unfortunately the sawhead isn't pushing freely over the log bed. It is leveled all the way around, so I can only assume that its a tad out of square. What is the best way to adjust the roller bearings on the sawhead the travel over the log bed?
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: sawmill head and log bed adjustments
« Reply #1 on: August 26, 2020, 11:54:42 AM »
Check the bed for square using a string and also check for parallel.
Is it tight all the way or just in certain spots?
Offline Patrick NC
« Reply #2 on: August 26, 2020, 11:55:36 AM »
My Timbery has the same track. Pull a string line down both rails to be sure its perfectly straight. If you have to adjust the roller bearings you will have to take the carriage off and take both assemblies off the bottom. Then you can loosen the nuts on each bearing. You will need to set each assembly on the rails and push the rollers against the track while holding the assembly square with the bed. Then re tighten the nuts and make sure they roll freely.
Offline Patrick NC
« Reply #3 on: August 26, 2020, 11:57:34 AM »
Almost forgot. Welcome to the forum and have fun sawing.
Offline WildWendi
« Reply #4 on: September 13, 2020, 01:33:09 PM »
Thanks everyone! I pulled strings on each side as suggested and that solved our issue. We are still getting use to sawing. We have cut quite a few logs now and today it has thrown me a new issue. I set the next log to be cut on the mill and the edge cuts came off nicely however the next 2 cuts seem to be either high or low in the middle. I double checked that both ends of the log were set at the same height on the bed with a tape measure but it still doesn't come out straight.  Help please!
Offline doc henderson
« Reply #5 on: September 13, 2020, 01:43:21 PM »
is it lifting due to stress in the tree, in the middle?  try cutting a series of 1/8th or 1/4 inch slices.
Offline WildWendi
« Reply #6 on: September 13, 2020, 01:46:36 PM »
From what I can tell and everything I have researched about it ,then it seems to be the tree itself. We tried a different tree and had no issues. Thanks, guess I w still cut it into boards to hang in my barn since I prefer the old natural look instead of " the perfect cut".
Re: Huskies - do they need adjustments out of the
Started by firtol88 on Chainsaws
Last post April 25, 2004, 10:24:08 PM
by firtol88
bandwheel adjustments
Started by coastlogger on Sawmills and Milling
Last post February 14, 2012, 11:44:10 PM
by eastberkshirecustoms
Spring adjustments
Started by bandmiller2 on Chainsaws
Last post April 16, 2015, 08:15:19 AM
by CR888
Sawmill Saw Head Thoughts
Started by dlh944 on Sawmills and Milling
Last post January 29, 2017, 12:16:54 PM
by Darrel
