Dynamic Green Products Inc.
Author Topic: Best all-around tires for tractor  (Read 620 times)
Offline livemusic
« on: August 31, 2020, 11:16:25 AM »
In another thread, I posted...
I need a tractor for...
bush hog a 7 acre pasture
occasional dirt work on lawn at home, garden and 50-acre woodlot
tree work at woodlot (firewood and whatnot)
leveling garden (will buy a box blade)
moving stuff now and then with FEL
What tire types do you think are best in that if/when I ever have to do dirt work on or take out a tree on my lawn, I would not want it to tear up my lawn real bad? That could be repaired but I was thinking ag tires might be too harsh? Annual rain is 54 inches. And then again, I likely would not put a tractor on it with ag tires if it were wet. Wondering if R4 is a compromise. It seems R4 would be easier on a lawn.
My brother has a small 23-hp Kubota with landscape or turf tires and they are not worth a hoot in the garden, I def would not want that! Of course, that would not work at all in the woods.
Bill
Offline PoginyHill
  • Gentleman logger
Re: Best all-around tires for tractor
« Reply #1 on: August 31, 2020, 12:20:17 PM »
I do much of the same tasks as you. I am happy with my R4s for the reasons you mentioned. They do have traction, but won't tear stuff up when turning hard or spinning a bit. I use chains in the winter. Ag tires would also need chains in the winter. I've never needed chains outside of winter and have gone thru some mudholes with some spinning, but never stuck. 4WD is a must in my opinion.
Kubota M7060, Cat E70B, Case 310, 750 Grizzly ATV, Wallenstein FX110, 84" Landpride rotary hog, Classic Edge 750, Stihl 170, 261, 391
Offline sawguy21
« Reply #2 on: August 31, 2020, 01:01:10 PM »
I had R4 tires on a 26 hp Kubota mostly used for mowing and occasional fel work as well as snow clearing. They were not much good in snow which won't be an issue for you but otherwise seemed to be the best compromise.
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #3 on: August 31, 2020, 03:42:36 PM »
Ag tires on the front will tear up the grass if turning sharp.  With that stated, my tractor has ag tires and when I buy new ones, they will also be ag tires.  The grass grows back too quickly anyway.  With ag tires, rear differential lock and limited slip up front, I still occasionally need to use whatever attachment I have on the front to get out of a bind.  Thankfully I have not encountered any ground like WDH did with his a few weeks ago.  My tires are loaded and the rear wheels are also weighted.
Caveman
Offline Southside
    • White Oak Meadows
« Reply #4 on: August 31, 2020, 04:24:06 PM »
How much will you be in the woodlot?  I ask because ply rating becomes rather critical pretty quickly in that situation.  A little staub that you clipped off with your saw suddenly turns itself into a Punji stick and takes out your tire in the worst possible location where you can't get a single tool onto it.
With that much rainfall I would likely stick with the Ag tires and deal with any lawn issues if and when they arise.  Probably use your chain / tow strap a lot less often in that scenario.  Loading your tires with beet juice might not be a bad idea too as it will help with traction and give you some "get to a good spot" time if you do poke a tire.
White Oak Meadows
Offline Riwaka
« Reply #5 on: August 31, 2020, 06:27:49 PM »
I don't think I have seen one machine that will do all those tasks to a class leading standard.
Probably do them with a garbage dump compact track loader or tough tractor with a lot of add on attachments
MECALAC | New Excavator / Crawler Excavator, high performance hydraulic excavator!
Mecalac 10 MCR with a few expensive add ons - grapple, mulcher etc. Cost more than regular excavator but have more power.
John Deere add tracks
Soucy tracks on small John Deere 4520 tractor, no flats
then add tougher cab for woods work
Exact-E cab on John Deere
Supertrak  the wheel loader is upped to 190Hp, winch on back could pull a twig or two.
Bobcat with mulcher on front
V519 VersaHANDLER Telescopic Tool Carrier - Bobcat Company
Merlo  multifarmer usa the small 136 horsepower, rear pto. Could put a logging winch on it. (there are tracked telehandlers that cost big bucks)
Merlo MF34.7 TCS ? Merlo
tracks for telehandlers - rear track clearance could be a problem for three point attahments on a
merlo mf
Offline BargeMonkey
« Reply #6 on: August 31, 2020, 09:38:47 PM »
Honestly depends how much time you plan on being "in the woods", like Southside said, R4 wont take a stick to well. Can still ruin an ag tire but it takes a little more. If your getting a deal on a machine it is what it is, buy a set of chains for the winter or when it gets greasy, learn how to use the breaks separately 😆
Offline thecfarm
« Reply #7 on: August 31, 2020, 09:56:44 PM »
AG tires all the way.
Those R4 are worthless.
Mighty worthless.
I had a tractor with ag's and one with R4. So I know how mighty worthless they are. Try digging a rock out on a downhill slope on grass when the ground is wet and back up with ag's. Than try just about the same place with R4's and you can tell the difference when the R4's sit there and spin.  ::)
About the only thing I find the R4's are good for is packing down a area that I brought in fresh dirt.
How many times are you on your front lawn? Three or four times a year?
Just about like me, maybe 3-4 times a year? I am out in the woods almost daily with mine. That is where I need the traction, not on my front lawn.
I have 8 ply tires, all the way around.
Offline mike_belben
  • Pulp Friction
« Reply #8 on: September 01, 2020, 07:04:29 AM »
The lawn needs aerating anyway.  No matter how many inches i doze off mine it keeps growing back.
Revelation 3:20
Offline mjeselskis
« Reply #9 on: September 01, 2020, 09:22:26 AM »
Mighty worthless.
Completely agree. After having both R4 and AG's, I hope to never own R4's again. I can drive my 55hp tractor with AG's on the lawn when needed without making a mess. The R4's were helpless in the snow, wet, and mud.
2006 WM LT28  1993 John Deere 5300
Offline moosehunter
  • Every once in a while
    • Saw it Coming
« Reply #10 on: September 02, 2020, 06:54:30 AM »
I have no experience with them but there is an alternative. R 3 is more aggressive than a turf tire or R4 but won't tear up the lawn like an R1.
R4s are for pavement and hard pack. They are as bad as racing slicks in mud!
mh
Higher than my expectations
Offline mike_belben
  • Pulp Friction
« Reply #11 on: September 02, 2020, 08:44:22 AM »
Rice and canes ftw.  You cant go wrong on paddy tires.
;D
Revelation 3:20
Offline btulloh
« Reply #12 on: September 02, 2020, 09:05:55 AM »
;D
:D :D :D
Yeah, the R2 tires are great for destroying a lawn and spinning on firm or hard ground.  If  that's what you need, R2's are just the ticket.
I was forced to put R2's on my L3250 a couple years ago.  That tractor was shipped with 26" wheels and some odd size on the front.  The ONLY tires that will fit are R2's (after a nationwide search).  The front tires really like to dig when turning because of the small contact area.  Good for shallow tilling.  I've gotten by with them - because I have to.  Unless you've got rice or cane fields, stay away from R2's.
My choice would always be R1 for general work.
HM126
Offline mike_belben
  • Pulp Friction
« Reply #13 on: September 02, 2020, 09:12:48 AM »
I loved em.  Our ground is clay and sand that doesnt freeze.  In the winter it slakes 3" deep or so and theyll dig until they get an armful, then lurch forward for the next one.
Revelation 3:20
Offline btulloh
« Reply #14 on: September 02, 2020, 11:28:47 AM »
I guess it comes down to using the right tool for the right job.
What I'd REALLY like is to have a selector switch that allows me to switch from R-1, R-4, Turf etc.  That should be easy, right?  :D
Offline Andries
  • Making buildings out of big curvy logs
« Reply #15 on: September 02, 2020, 11:35:42 AM »
You already have one of those switches.
The ignition switch.
Just get two more machines, that'll be three ignition switches, and presto!
Mark the keys: R-1, R-4, Turf
Instant tires switchers!
:D ;D :D
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline square1
« Reply #16 on: September 03, 2020, 05:28:11 AM »
Just put new R1s on this week. It's a lot less work to fix a few marks in the lawn than it is to unstick a stuck tractor
tractor tires
Started by LeeB on Wanted
Last post May 03, 2008, 12:48:12 PM
by jokers
Tractor Tires
Started by smwwoody on Forestry and Logging
Last post June 06, 2011, 10:07:36 PM
by tyb525
11.2-34 tractor tires
Started by Beaudeane on Wanted
Last post September 01, 2012, 04:58:57 AM
by Al_Smith
tractor tires.
Last post January 30, 2009, 01:58:31 AM
by LeeB
