Author Topic: 372 safety brake fix ??  (Read 149 times)
Offline Gearbox
« on: September 06, 2020, 09:20:54 PM »
Does anyone have a cure for the worn pin that lets the brake engage without bumping the handle . I have cleaned it and it is some better . I blow it out with air often but now it is getting worse . This 372 I run on the processer so I can tie the handle back but I would like to fix it .
Offline sawguy21
Re: 372 safety brake fix ??
« Reply #1 on: September 06, 2020, 10:11:35 PM »
I found the breakdown on Partstree, parts are readily available.
Offline Gearbox
« Reply #2 on: September 07, 2020, 01:21:50 PM »
From the little I can find the wear is in the case and there may be a oversized pin to drill out and install . I just need to figure out a part # or who makes it . I will look on Parts Tree
i just cant get a brake
Started by coxy on General Board
Last post May 08, 2014, 01:22:26 PM
by sandhills
TJ 330 brake problem
Started by rockwall on Forestry and Logging
Last post November 13, 2012, 10:00:23 AM
by deerguy
brake problem on 240 TJ
Started by Woodboogah on Forestry and Logging
Last post July 10, 2013, 05:12:09 PM
by coxy
I brake for bugs
Started by WV Sawmiller on The Outdoor Board
Last post September 03, 2017, 03:21:40 AM
by Kbeitz
