Author Topic: Cant hook and peavey storage  (Read 921 times)
Offline davch00
« on: September 10, 2020, 11:10:02 PM »
For those that have stationary mills, How do you store cant hooks? I'm currently just leaning mine against the wall, or more often on the ground after it gets knocked over. I think I would like to hang them up if possible but haven't came up with a way to do that yet. All of mine are logrites if that helps.
Offline hopm
Re: Cant hook and peavey storage
« Reply #1 on: September 10, 2020, 11:53:06 PM »
Mine goes in a sleeve welded on front of mill.
Offline donbj
« Reply #2 on: September 11, 2020, 12:20:47 AM »
Mine leans up against the hitch at the front of the mill. It always ends up there so it's easy to grab
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065
Offline JoshNZ
« Reply #3 on: September 11, 2020, 01:21:33 AM »
If it's hollow, weld a length of round bar or rebar to your frame out of the way? Or if it's not, a piece of pipe to stick the end into.
Offline Dana Stanley
  • For fun and profit!
    • Stanley Carpentry Construction
« Reply #4 on: September 11, 2020, 05:53:17 PM »
For now my shed is small so I lean them up against a 2x4. when I make a bigger shed, I want to hang them horizontally, like on a gun rack, or just long screws or nails.
Making Sawdust, boards and signs.
Woodland Mills HM-126
Kabota B-7800 with backhoe and loader
Ford Ranger, Husqvarna 455 20", Mac 610 24", other chainsaws 14", 23 ton log splitter
Matthew 3:10
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #5 on: September 11, 2020, 06:36:22 PM »
Peavey sticks in the ground up right. Cant hook is always at my end leaning on the hitch.
Offline Southside
    • White Oak Meadows
« Reply #6 on: September 11, 2020, 09:07:02 PM »
X2 on sticking it in the ground - it has a point so I use it.
White Oak Meadows
Offline hopm
« Reply #7 on: September 11, 2020, 09:22:39 PM »
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #8 on: September 11, 2020, 09:29:24 PM »
   I think the MagicMan hauls around a 40' storage container full of his. I heard he injured his leg last year because he opened the door of the container and the load had shifted and several dozen fell out on top of him and they had to get a loader to dig him out. :D :D :D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9 on: September 11, 2020, 09:53:06 PM »
A man gots to do what a man gots to do.  logrite_cool
Offline Southside
    • White Oak Meadows
« Reply #10 on: September 11, 2020, 09:56:39 PM »
Hopm - that thing is camouflaged there!!  It's like a sawyers game of "where's Waldo"?
White Oak Meadows
Offline hopm
« Reply #11 on: September 11, 2020, 10:29:00 PM »
Donít really help much but I always wanted to highlight like that...it does make my harbor freight level jump out 😂😂😂😂
Offline Woodpecker52
« Reply #12 on: September 12, 2020, 01:05:49 AM »
I just stick mine up with the hook between some rafters and let them hang down, works for me. I made two smaller ones with handles about  3 feet long for small logs and have a couple of medium size ones and one old antique one for the virgin logs.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline Roundhouse
« Reply #13 on: September 12, 2020, 02:04:36 AM »
When I built my toolshed last year I put in a couple screws that the cant hooks hang from just inside the door. It's tough to see in this photo but there is one screw sticking out about 2" from the wall that the hook part of the cant hook hangs on. A large hook at the top of the wall keeps the used blades in place. On the opposite side of the doorway is the same set-up for new blades with another cant hook hanging in the middle. This keeps them out of the weather and out of the way when I'm not milling. When I am milling they are out leaning against a post under the sawmill shed.
Woodland Mills HM130, 1995 F350 7.3L, 1988 F350 dump, 1938 Allis-Chalmers reverse WC tractor loader, 1979 Ford CL340 Skid Steer, 1988 Yamaha Moto-4 200, various chain saws
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #14 on: September 12, 2020, 08:29:34 AM »
Simple:
Just lean it against a tree or.....
Hang it on da wall.  logrite_cool
Offline ScottCC
  • New ideas welcome
« Reply #15 on: September 13, 2020, 07:31:26 AM »
A round steel plate with a pipe weld perpendicular to it in the middle.  Holds it vertical anywhere and easy to roll around with peavy handle to move.
Necessity is the mother of invention.  Poverty is its big brother.  WM mp100, WM eg100, WM sp4000 chip extractor,  WM 260 molder on order ,WM electric  lt15 wide with extra track, 71 Oliver allterrain forklift, 26' flat bed trailer, road legal log arch, homemade kiln, AutoCAD lt15
Offline Gere Flewelling
  • Hobby Miller
« Reply #16 on: September 13, 2020, 08:06:47 AM »
This is interesting.  All this time I thought they were designed to be leaned against something and fall over so you can trip over them constantly. :D That's how I have always kept track of them.  Who says you can't teach an old dog new tricks?
Old 🚒 Fireman and Snow Cat Repairman
Offline hopm
« Reply #17 on: September 13, 2020, 12:30:39 PM »
And donít forget all the grace and poise of looking at the ground....turning round and round trying to find it 😂😂😂
Offline Redhorseshoe
« Reply #18 on: September 13, 2020, 04:40:14 PM »
The little hole in the tractor loader makes a handy storage spot when not in use.  The rest of the time it's leaning against the tool and accessory block.
Offline Walnut Beast
« Reply #19 on: September 13, 2020, 07:12:04 PM »
You could drill a hole in your tool block to hold your canít hook in the upright position for quick access
Cant Hook, vs Peavey
Started by Nate Surveyor on Sawmills and Milling
Last post December 03, 2007, 11:07:10 PM
by Dave Shepard
Cant Peavey Hook
Started by 4x4American on Sawmills and Milling
Last post July 30, 2015, 08:02:01 AM
by Magicman
Peavey-cant hook ???
Started by Beaudeane on Sawmills and Milling
Last post January 20, 2013, 07:21:17 PM
by SwampDonkey
Cant hook vs. Peavey
Started by ljohnsaw on Sawmills and Milling
Last post November 11, 2012, 08:06:46 AM
by bandmiller2
