Dynamic Green Products Inc.
Author Topic: Got some sycamore logs, I wonder what I should do with them?  (Read 347 times)
Offline Snowman1988
« on: September 11, 2020, 11:24:03 PM »
Got some really nice sycamore logs today!
What should I do with them? I cut them in 8 6 lengths and longer the largest log is about 26 in diameter
I was thinking about Quarter sawing them in to 2x4s for a solar kiln build. Im not real sure what to do. What would you do with them?
Offline Southside
    • White Oak Meadows
Re: Got some sycamore logs, I wonder what I should do with them?
« Reply #1 on: September 11, 2020, 11:39:36 PM »
QS Sycamore is gorgeous.  If it's clear I would look to saw it 9/4, dry it, then finish it for tables and other furniture lumber.
White Oak Meadows
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #2 on: September 12, 2020, 06:44:37 AM »
Definitely quartersaw it.  It warps and twists really bad if flatsawn.  If I can't quartersaw it, I won't saw it at all.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #3 on: September 12, 2020, 08:15:41 AM »
Quartersaw and sell the lumber.
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  Dont burn the cookies.
Offline kelLOGg
« Reply #4 on: September 12, 2020, 12:11:32 PM »
Ditto on all the above. I love that wood.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Silverfoxfintry
« Reply #5 on: September 12, 2020, 03:59:05 PM »
I milled a small Sycamore log 20 years ago. I kept it for 18 years before I turned the slabs into Chopping-boards a couple of years ago. I managed to get 70 per board.
Winter cut Sycamore is very white. I am told it has certain Anti- Bacterial properties.
Keep safe
Iain
Sycamore logs
Started by johnnyllama on Sawmills and Milling
Last post September 06, 2016, 10:27:11 PM
by Joey Grimes
sycamore logs.
Started by Taylortractornut on Sawmills and Milling
Last post June 06, 2011, 01:07:03 AM
by DRB
Sycamore Logs
Started by GarryW on Sawmills and Milling
Last post December 24, 2002, 04:55:57 PM
by Noble_Ma
Sycamore logs
Started by alanh on Sawmills and Milling
Last post August 23, 2020, 03:20:09 PM
by Tom the Sawyer
