Author Topic: Swingblade Sharpening, when to change tips?  (Read 275 times)
Offline quadracutter222
  • D&L 10/20, Kubota XD23, Long 5n1, MS461
« on: September 13, 2020, 11:11:42 PM »
Hello all, a quick question for circle/swing blade folks.
How do you know when your tips have had their last sharpen?  I have heard there is a width over the thickness of the side plate, but have yet to nail it down.
Cheers!
Offline Ianab
Re: Swingblade Sharpening, when to change tips?
« Reply #1 on: September 14, 2020, 12:59:07 AM »
I don't have any exact number, but I find that as the tips get worn down they become more prone to chipping / breaking. When that happens it's time to swap out the blade and get it re-tipped. You often don't even notice a tooth missing until you go to sharpen.
Online Don P
    • Calculator Index
« Reply #2 on: September 14, 2020, 08:02:38 AM »
About half of ours get damage, the rest slowly change sound, require more effort and we've run a couple till they start rubbing the plate and getting hot and flutter, well overdue.
Offline scsmith42
    • Whispering Pines Farm
« Reply #3 on: September 14, 2020, 09:43:55 PM »
I've run tips down to where they were 1/8" or so thick w/o any problems.  Usually they start chipping first.
Tom's 3638D Baker band mill
Offline longtime lurker
« Reply #4 on: September 16, 2020, 03:12:59 AM »
yeah soon as your cuts aren't intersecting right, or they're just looking thin.
Mind I run oversize teeth where I had to recut the pockets due metal fatigue so... different alloy, mine are a bit softer than the factory spec so less brittle and don't chip out ... individual mileage may vary.
Any D & L Swingblade owners wanting to share tips and problem solve?
Started by wdncno on Sawmills and Milling
Last post December 03, 2008, 09:47:36 AM
by wdncno
Blade sharpening tips
Started by dhp3228 on Sawmills and Milling
Last post February 12, 2016, 05:49:49 PM
by 4x4American
exclamation
Share your tips for sharpening in the field..
Started by RBC2404 on Chainsaws
Last post September 28, 2019, 10:52:00 AM
by WV Sawmiller
Change band brands...change tracking?
Started by kelLOGg on Sawmills and Milling
Last post July 21, 2014, 05:56:28 PM
by ladylake
