Dynamic Green Products Inc.
Author Topic: wood mizer hyd lt35 vs lt35hd purchase  (Read 959 times)
Offline widetrackman
« on: September 25, 2020, 06:18:03 PM »
Well I am a newbie to band saw mills but now is the time to purchase one as i have 250 ac of pine and hardwood and something is always falling due to storms. I think I will buy a WM and clean up as well harvest some lumber. Most of the hardwood is 24-26" and 22" pine except for about 35 left that are 36" x 70' 65 yrs old and have lost another 5 in the last 3 years. First off I can not afford a Lt40 and will consider a LT35 w/ hyd pck ($15,995 + 3995 = $19,990 or the LT35HD hyd @ $23,595. My concern is that it cost $3605 more to get hyd toe board and 2 hyd clamps, manual toe board is no big deal but $3605 for 2 hyd clamps I question. Seems way to much for the two, what do you guys think $ are real tight. Also to mill my 36 " pine with a 32 " machine what would guys do, I dont have a chainsaw mill or alaska mill. Advice appreciated.
Offline Haleiwa
  • Clinton county, New York
Re: wood mizer hyd lt35 vs lt35hd purchase
« Reply #1 on: September 25, 2020, 06:31:22 PM »
Hydraulic clamp is about the last thing I would give up.  Every time you turn a log you have to loosen and retighten the clamp, and if it is easy, you will be more likely to do it when it is needed, rather than take one more cut before you turn the cant.  As for the bigger logs, you will probably be able to handle some of them if you take the butt flare off with a chainsaw; only a small portion of the log is the widest diameter.  Not very graceful, but I have seen large logs split by hand with a chainsaw with a long bar, and the two halves milled separately.  It wastes some boards, but if you only have a few, it might be the easiest way to deal with them. Talk to your closest dealer; sometimes there are a few good used mills out there for less than the price of a new, or at least for the same price as a new base unit with some extras installed.
Socialism is people pretending to work while the government pretends to pay them.  Mike Huckabee
Offline A-z farmer
  • Still learning
« Reply #2 on: September 25, 2020, 06:33:46 PM »
With that many acres of trees I would get the all hydraulic lt35.You will not be disappointed and it will be easier on you after a day of sawdust .
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: September 25, 2020, 06:41:02 PM »
  I think what you are calling the 2 hydraulic clamps are the extra side supports. Get them! They make all the difference in the world if you are sawing something shorter than 8'. IMHO they should be standard vs an option. There is only one movable hydraulic clamp on mine. Be sure to make yourself a Magic Hook to use with it for those big or odd shaped logs that do not want to roll on to the loading arms.
 The toeboards are great for leveling the pith of the log and are helpful when rolling a stack of finished boards or a heavy plank off the end on to a waiting trailer or forks. (They are also essential for making long wedges when you forget to lower one but that comes later. :D)
 I also swear by the debarker. They are great mills and I know you will be happy. Keep us posted on your successes and any uh-ohs (We've all been there and will laugh with you not at you.)
  On those oversized logs you may be able gunbarrel them making thin cuts off the top then rotating slightly and repeating till the log fits your mill. I think all of us have processed an oversized log or two and if just an occasional one don't sweat it.
Offline Durf700
« Reply #4 on: September 25, 2020, 07:11:26 PM »
I recently purchased an LT 35 Hydraulic mill and came from a manual LT 15.  the LT 35 Hydraulic is an awesome mill... definitely get the debarker and the extra 2 hydraulic log clamps.. I'm 42 years old and in good shape.. I would not even think about milling again with a manual mill after getting spoiled with the LT 35 HD... I feel alot better and can produce 3 times as much lumber per day vs my old manual mill and not ache as much.. I still smile every time I have to spin the log around and filip a cant to take a little off the opposite side.. just a few levers and your off again milling!
you can find them very lightly used sometimes..  I picked mine up 8 months old with 140 hours like new for 17k delivered to my door still with lots of warranty left and about 50 blades.  if brand new is what you want and can afford it then go for it..  if not keep an eye on FB or FB woodmizer owners..
let us know what you decide!!!
Offline Nodak Andy
  • ya sure you betcha
« Reply #5 on: September 25, 2020, 08:22:39 PM »
I just saw a 2013 LT35HD on a FB sawmill sales page for $17000.  Ad said it was out in PA at a woodmizer dealer.  Don't remember exactly where though... Had to keep scrolling to prevent divorce....
Offline Nodak Andy
« Reply #6 on: September 25, 2020, 08:36:00 PM »
Found the post.  Just says to call PA Woodmizer.... Says 520 hours. LT35HDG25 with debarker
« Reply #7 on: September 25, 2020, 09:09:28 PM »
BTW if anybody spots a used LT 40 please post it. Thanks
Offline thecfarm
« Reply #8 on: September 26, 2020, 06:31:39 AM »
widetrackman, welcome to the forum.
You will need a Logrite cantdog or a peavey too. Sponsor on the left. Nice people, made in the USA.   logrite_cool
What's all the lumber going to be used for?
You will like sawing.
How will you get the trees out of the woods?
Offline rooster 58
  • GRIZ, the sawmill mgr.
« Reply #9 on: September 26, 2020, 07:16:35 PM »
I have an lt35hdg25 available
Offline woodweasel
  • I'm No Longer New, But Green As A Gord
« Reply #10 on: September 27, 2020, 04:28:10 AM »
Spend the money for the Hydraulic. 😉😉
Offline Durf700
« Reply #11 on: September 27, 2020, 01:57:44 PM »
looks like this could be your mill??  no wait time..
Online WV Sawmiller
« Reply #12 on: September 27, 2020, 02:23:15 PM »
    We don't know his location so may not be an option. Don't forget to pay the piper (FF) the appropriate finder's or seller's fee if you do this deal since it all came from right here. Fair is fair. ;)
Offline rooster 58
« Reply #13 on: September 27, 2020, 04:36:06 PM »
I am near Colorado Springs,  Colorado.  And yes, if there is interest,  we will certainly go about it the right way
Offline richhiway
  • Rich
« Reply #14 on: September 27, 2020, 04:44:23 PM »
Hyd mills are worth every penny. I have a manual LT 40 and it is a lot of work.
Debarker will pay for itself in blade life.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #15 on: September 28, 2020, 10:31:08 PM »
My first mill was manual until I built hydraulics for it, then when I upgraded, hydraulics was the most important option....
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch.
Offline Southside
    • White Oak Meadows
« Reply #16 on: September 28, 2020, 11:04:27 PM »
Well - go fell a 22" oak and buck it to 16'.  Then mark a spot with paint as a reference.  Grab your peavey - which you will need with any mill - and start rolling that bad boy around.  Try to get the painted reference mark to stop at 3:00, then 9:00, then 12:00.  Now come up with a rough estimate of how many times you plan to do that as you harvest your 250 AC of land.  If you still think the difference in price is worth it then skip the hydraulics.
Personally I find it quite satisfying to every now and then spin a log round and round using just my right thumb, as folks stare in wide wonder, but that is just me.  ;D
White Oak Meadows
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #17 on: September 29, 2020, 12:17:19 AM »
Not just you. Sometimes I can debark a log with my right thumb in a few seconds like that.
Offline barbender
« Reply #18 on: September 29, 2020, 12:34:50 AM »
Do you all remember that time everyone on here recommended a member get the hydraulics, he did, and then about 3 weeks later he came back on on here.  Fit to be tied. Bitterly angry with his decision to spend the extra and make his life easier. He was so nasty and angry with everyone I think Jeff had to ban him. Anyone else remember?😉
« Reply #19 on: September 29, 2020, 01:51:18 AM »
Well I was thinking about "rooster's" LT35 but wife said to far off to see and was pushing me to order a new LT35hd w/debarker--- How could I resist,  sooo I ordered one this afternoon 8) . Delivery 10-12 weeks  :o Going to miss the best time to create saw dust this year.
New! Wood-Mizer LT35!
Started by Bibbyman on Sawmills and Milling
Last post October 23, 2010, 08:47:21 AM
by Coon
smiley
Just got my New Wood-Mizer LT35 Hyd
Started by JHEchevers on Sawmills and Milling
Last post July 05, 2014, 10:23:56 AM
by delvis
wanted: wood mizer lt35 hd or 40 hd
Started by sceptre74 on Wanted
Last post March 11, 2016, 10:19:58 AM
by sceptre74
Wood-mizer LT35 v/s timberking 1600
Started by red pine on Sawmills and Milling
Last post March 22, 2011, 09:17:19 AM
by red pine
