Dynamic Green Products Inc.
Author Topic: Stihl 170 and 180  (Read 280 times)
Offline Blue67bird
  • Member*
Stihl 170 and 180
« on: October 06, 2020, 06:50:34 AM »
Hey everybody, my first post but one I consider very serious. I have a number of Stihl chainsaws and a MS 170 in particular which I bought for light work and has been used occasionally but is now just out of warranty. Recently after use I went to the kill switch but the engine would not stop. After searching YouTube it became obvious that the matter could be resolved by ad hoc modifications to the manufacturer designed choke/on/off system used in millions of Stihl petrol chainsaws. If this had happened in the auto industry there would have been a wholesale product recall. This appears to be a serious safety issue as a result of poor design. Anyone here experienced the same problems and give some ideas to resolve the matter.
Offline lxskllr
  • dummy with saw
Re: Stihl 170 and 180
« Reply #1 on: October 06, 2020, 09:50:40 AM »
Quick and dirty, set it to full choke. Correctly, fix the switch.
Offline Caloren
  • 1940 9N ford
« Reply #2 on: October 06, 2020, 10:00:26 AM »
The 170 is the saw I use the most, and have been using it for 15 years and never had this problem.
Stihl MS 170, Stihl MS 310, Stihl 028 AV Super, and half a dozen other no-accounts! Cat D4 D.
Offline Tacotodd
  • To learn and help
« Reply #3 on: October 06, 2020, 12:06:34 PM »
Iím not currently a Stihl owner but surely itís not that overwhelming of a job to go in and check to see if itís grounding out the ignition for properly  shutting off the engine. Either itís the multi function switch or a bad connection somewhere. Go back to your basic electrical workings and just remember that a basic continuity meter is your friend in doing so.
Trying harder everyday.
Online btulloh
« Reply #4 on: October 06, 2020, 12:18:52 PM »
Those stihl switches get out of whack sometimes. Usually you can easily adjust the grounding contact on the switch and fix the issue.
HM126
Offline Tin Horse
« Reply #5 on: October 06, 2020, 07:46:01 PM »
Can't recalled the saw I had a similar issue with but I'm now in the habit of cleaning debris on my saws with compressed air. It solved the shut off switch issue.
Bell 1000 Wood Processor. Enercraft 30HTL, Case 580SL. Kioti 7320.
Does Stihl have a different mount size at the studs for bigger and smaller Stihl
Started by quietrangr on Chainsaws
Last post October 09, 2011, 08:25:11 AM
by Al_Smith
Mounting Cannon S2 (big Stihl) 42" bar on MS661 (small Stihl)
Started by neildorin on Chainsaws
Last post September 11, 2017, 06:01:44 AM
by Al_Smith
Stihl can't start the Stihl MS310 !
Started by mrcaptainbob on Chainsaws
Last post February 10, 2020, 09:53:28 PM
by mrcaptainbob
There are Stihl dealers then there are Stihl sellers.
Started by Ward Barnes on Chainsaws
Last post July 28, 2020, 05:40:50 PM
by WV Sawmiller
