Dynamic Green Products Inc.
Author Topic: Old Stihl 026. No spark.  (Read 132 times)
Offline 2xbarreled
  • Member*
« on: October 07, 2020, 01:06:55 PM »
New guy here.  My beloved Stihl 026 has finally stopped running.  Has compression, but most likely low.  Zero spark with plug removed from head.  Purchased after market coil, still no spark.  If flywheel aids in spark, could that be my issue?  Where do I go from here?  Please advise. Thanks 👣
CMC
Offline Mad Professor
Re: Old Stihl 026. No spark.
« Reply #1 on: October 07, 2020, 01:14:05 PM »
How is the plug and did you gap the flywheel/coil?  How are you grounding the plug?  Is kill wire and switch working?  Insulation on coil wire?  Check switch/kill wire with ohm meter to ground on cylinder
Take a peek at the piston through ex port if you get spark back and it still don't run
Offline JoshNZ
« Reply #2 on: October 07, 2020, 02:56:34 PM »
Slim chance it's the flywheel. Unless it's thrown magnets or something and I'm sure you'd know about that. My guess would be a failed switch. Leave the kill switch wire disconnected and floating and try it. And make sure you try a new plug! I used to scoff at people saying try a new spark plug until I saw one that looked perfectly fine fail completely one day
Stihl 88 no spark.
Started by Joe Hillmann on Chainsaws
Last post November 08, 2014, 05:06:19 PM
by sablatnic
Stihl MS261 no spark
Started by buckwheat1 on Chainsaws
Last post October 17, 2018, 07:21:08 AM
by Mad Professor
stihl 025 chainsaw has no spark?
Started by firefighterfox on Chainsaws
Last post February 11, 2012, 09:24:18 AM
by JohnG28
Stihl MS280 no start (no spark?)
Started by CarlMs280 on Chainsaws
Last post May 06, 2010, 09:07:57 PM
by Cut4fun
