Dodge carrier bearing
Started by azmtnman, November 11, 2020, 09:49:31 AM
azmtnman
Anybody else having trouble keeping carrier bearings in their Dodge? My 3rd one in less than 75,000 miles just went out. smiley_huh
I have a 2003 4x4 crew cab with 8' bed, 305hp Cummins and a 6 speed manual and keep trashing carrier bearings. It isn't lifted. It's generally the rubber part that goes bad.
  I've been told to check my transmission mounts and maybe get the driveshafts balanced. It got new u-joints when the last one went out about 20-25k miles ago.
1983 LT 30, 1990 Kubota L3750DT, 2006 Polaris 500 EFI, '03 Dodge D2500 Cummins powered 4X4 long-bed crew cab, 1961 Ford backhoe, Stihl MS250, MS311 and MS661--I cut trees for my boss who was a Jewish carpenter!
mudfarmer
Quote from: azmtnman on November 11, 2020, 09:49:31 AM
A lot of guys seem to be replacing the 2piece driveshaft on Dodges with a 1piece from somewhere like Driveshaft Specialist Inc due to carrier bearing failures. Sorry to hear it keeps happening to you
Corley5
Have you tried a different brand of bearing?  I've had some quality issues with after market parts lately.
Real1shepherd
You might want to find out where the carrier bearings are being made. The rubber in carrier bearings and CV boots for example are highly suspect coming from Asia....specifically from you-know-where.
I have a '95 Dodge 3500 work truck with the V-10. It's had one carrier bearing so far in 200,000 miles with the NV-4500 5spd.
Kevin
mike_belben
Dont go to a 1piece driveshaft.  Theyre hard to keep balanced.  I cut mine into a long single and had to spend quite a bit to go back to 2pc after lots spent trying to stop the shake.  A shaft that long can bend itself.
Praise The Lord
Real1shepherd
Exactly right. Don't abandon a good design because the cheap Asian rubber is failing in aftermarket carrier bearings.
I'm not 100% even sure I ever replaced my carrier bearing, but I assume I have after all this time. It has never been an issue is what I'm trying to say.
Kevin
sawguy21
My 05 with over 200,000 miles, American model, has never had an issue. I wonder if you have an alignment problem.
Real1shepherd
There was a balancing issue in the beginning of the new Series('94 on) and I had my whole driveshaft assembly replaced under warranty.....although there was no noticeable issue with mine.
In addition to the usual balancing weights, there is a big balancing disc. But then after the 5spd and different engine combo's, I haven't kept up.
Kevin
barbender
I have an 03, 305hp 6 speed as well. It was eating carrier bearing rubber mounts too. My 97 also has a 2 piece shaft, never had a problem with that carrier. Nor do the thousands of heavy duty trucks that are equipped with 2 piece drive shafts. The carrier bearing and mount for a '97 will fit right on your '03, they are like a heavy truck style instead of that flat rubber pancake junk on the '03. Just make sure you get the right size, I believe they are 1.5". You're welcome😁
Dave Shepard
I was at my dealer many years ago and there was a '94 3500 extended cab diesel in their shop for it's first non scheduled repair, which was a carrier bearing. Truck had 494,000 miles on it and had only had oil changes.
mike_belben
Unfortunately someone is asking $14k for that truck right now at 605k miles.. "Just broken in."
Praise The Lord
Real1shepherd
Quote from: Dave Shepard on November 12, 2020, 09:41:20 AM
I've seen and worked on cream puffs like that which only carried people around to jobs. Some supervisor's truck or whatnot who had every single service done on it. Unfortunately for the rest of us, our trucks are worked hard. If I had bought anything less than a 3500, it would be rubble by now. My truck was even rigged as a well pump truck for a number of yrs and was about 15,000lbs loaded everyday.
I just went through the NV-4500 to rebuild. I found it in amazing shape inside, albeit the fifth gear shaft lock nut was only finger tight. It's essentially a 4spd box with 5th added on outside the main tranny case. Don't ever buy any heavy duty Hays clutches...junk. Total failure of the pressure plate. In all the yrs of running manuals in trucks, I've never seen this. Worn clutch dics, sure....completely worn out pressure plate, no.
Kevin
azmtnman
Quote from: barbender on November 11, 2020, 10:31:13 PM
Ding, ding, ding!
We have a winner! Thanks, @barbender !
There's no knowledge like real world experience. That's why I love this forum! (That, and the high rate of honesty and decency you can't find elsewhere on the internet!)
I will try that!
barbender
Dave Shepard
Quote from: Real1shepherd on November 12, 2020, 10:15:52 AM
Kevin
The guy recovered crashed Cessnas. All long highway trips with relatively light liads.
Real1shepherd
Quote from: Dave Shepard on November 12, 2020, 07:22:14 PM
Kevin
When I worked at a gold mill up in Silverton, CO....the BIG boss would come down occasionally form Canada. His truck was immaculate...you could eat out of the engine bay and it had a lot of miles. The truck was used just to haul his butt around. I was the only one he would let work on it. I was never a very good participant in that step 'n fetch game, but he was decent enough.
Kevin
