Dynamic Green Products Inc.
Author Topic: Blade width on No Name Mill  (Read 603 times)
Offline shadowdev
« on: November 12, 2020, 04:39:48 PM »
Hi Everyone,
I have a No Name mill that came with a 1" blade of which I'm having trouble finding replacement blades. Most manufacturers deal only with 1-1/4" blades.
How would I know if this mill will accept a 1-1/4" blade?
Below are a couple of pictures of the wheel and blade guide assembly.
Thank you very much,
SD
Online SawyerTed
  • Summey Lumber Services, LLC
Re: Blade width on No Name Mill
« Reply #1 on: November 12, 2020, 06:31:17 PM »
Id try to see if a blade supplier would send a pack of 3 to 5 1.25 blades and see how they work.  You might have to adjust tracking a bit but finding blades you can use would be worth it
Woodmizer LT35HD25, WM BMS 250, WM BMT 250, Kubota MX5100, IH McCormick Farmall 140, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Online btulloh
« Reply #2 on: November 12, 2020, 07:28:26 PM »
Member @cutting_edge will sell a small number of blades. Dont know where youre located, so he may be in your region - or not. (Probably a good idea to fill in your profile so we can provide better answers. )
Looks to me like that machine will handle 1.25 blades though. If not, you can always get any blade stock made to any length.
Offline moodnacreek
  • Sawin by the notches
« Reply #3 on: November 12, 2020, 08:51:36 PM »
Hi Everyone,
SD
Bandsaw bands are made in almost any width and cut and welded to any length you ask for.
Offline Southside
    • White Oak Meadows
« Reply #4 on: November 12, 2020, 08:55:29 PM »
Looks like it would be fine with a 1 1/4.  Just make sure you have enough clearance between the covers and the wheels to get the band on and off.
White Oak Meadows
Offline RAYAR
  • Retired May 2/19 more time to play with my mill
« Reply #5 on: November 12, 2020, 11:07:41 PM »
It looks to me like that mill may have "B" type belts. If so, they usually run 1-1/4" blades on them. If the shaft size those pulleys are mounted on are at least 1-3/8" diameter, then they will take the tension required by 1-1/4" blades.
mobile manual mill (local build) (mods & additions on-going)
Shop built auto band sharpener
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans
Offline shadowdev
« Reply #6 on: November 13, 2020, 04:11:39 PM »
Thank you everyone,
To reiterate, the blade that came on the saw is 161x1x.35 and I've called Cooks who can make replacement blades but they also need to know the Minimum & Maximum spread. At the moment it's pouring outside and so that measurement will have to wait.
Figure that I'll order a 5 pack with at least 1 of a 1-1/4 blade and see if it works.
It'll be a week or two before I have blade but will keep ya'll posted.
Thank you again,
SD
Online trimguy
« Reply #7 on: November 13, 2020, 08:47:38 PM »
When you check your minimum, if 158 will work , its a common size and they wont have to be custom made. Probably will lose a little on your cut width though. If you fill in where your from , maybe someone would have one you could try on before ordering. Im in Augusta ga.
Offline Iwawoodwork
« Reply #8 on: November 13, 2020, 09:59:09 PM »
Also you have to look at your blade guides if you change widths and where the guide rollers run on the blade, can't be to far out on the tips. so when you get your new blade aligned on your band wheel be sure to check your guides.
Offline Cutting Edge
    • Cutting Edge Saw Service, LLC
« Reply #9 on: November 14, 2020, 06:48:55 AM »
Your guides (bearings) would work better, if the surface area they contact were wider, especially for 1-1/4" wide blades.
Pay attention to the bearings that run behind the blade... Tracking should keep the blade forward 1/8" of that surface.  Running the back edge against those is a quick way to break a blade.
1-1/4" wide blades will serve you best.  Blade thickness is best determined by bandwheel diameter for longevity vs. cut quality.
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
 - Sharpening Services
 - Portable/Custom Milling and Slabbing
 - On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blades
Ph- (304) 878-3343
Offline shadowdev
« Reply #10 on: November 17, 2020, 12:24:20 PM »
Hi Trimguy,
After measuring carefully the Minimum blade size is 160.5" and the Max is 161.5", so it looks like a custom order is the way to go.
SD
Offline shadowdev
« Reply #11 on: November 17, 2020, 12:27:58 PM »
Hi Iwawoodwork & Cutting Edge,
I'm reinstalling the original blade today (had it off for measuring) and will look to get the alignment as you've instructed. I took the entire wheel assembly apart to figure out exactly how it works and am now much more confident in ensuring the alignment.
Thank you,
SD
Offline shadowdev
« Reply #12 on: November 24, 2020, 08:13:58 PM »
Hi Everyone,
Purchased Cooks 5 blades (1x160.5+) and a 1.25 to try.
Haven't installed yet but reasonably confident in the measurements.
Thank you to all,
SD
Width of your band wheel, width of your blade?
Started by valley ranch on Sawmills and Milling
Last post March 09, 2015, 12:41:02 AM
by valley ranch
Min. blade width?
Started by tacks Y on Sawmills and Milling
Last post June 30, 2016, 09:33:24 PM
by tacks Y
Blade Width vs HP
Started by D Martin on Sawmills and Milling
Last post March 21, 2007, 09:16:42 PM
by D Martin
Blade Band Width
Started by MartyParsons on Sawmills and Milling
Last post May 21, 2007, 07:54:28 PM
by theorm
