Dynamic Green Products Inc.
Author Topic: Metal base on oak Post  (Read 240 times)
Offline flatrock58
« on: November 20, 2020, 09:36:47 PM »
I am planning on making a timber frame shed porch on the side of my shop in the next few months.  I was going to anchor the 8x8 white oak post to the slab using OZCO metal post bases.  Will I have problems with the metal lag bolts in the post base?  If so will stainless lag bolts solve the problem?
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Cooks Dual Tooth Setter
Solar Kiln
Offline fishfighter
Re: Metal base on oak Post
« Reply #1 on: November 21, 2020, 09:14:26 AM »
Biggest problem will be trapping water under the post and metal base. To help, I had bolted the base down. The hex bolt heads stuck up about a 1/4". The post sat down on them. That gave a gap in between the two were air will pass and dry things out.
Offline kantuckid
« Reply #2 on: November 21, 2020, 09:27:16 AM »
My 6x10 oak beams sit on edge on concrete piers with termite shields and roll foam sill underneath and bolted via hot dipped 5/8" J-bolts. For your post job look through the Simson-Strong tie catalog? I saw custom welded steel brackets you could use for sale on FB marketplace by the person fabricating them. Odd lots & surplus, etc.,  sold cheaper on ebay & FB from leftovers brackets and fasteners too.
Online Don P
    • Calculator Index
« Reply #3 on: November 21, 2020, 04:07:50 PM »
HDG lags or coated ledgerlok type lags would be cheaper alternatives with good corrosion protection, less than SS but far better than regular lags.
Offline kantuckid
« Reply #4 on: November 22, 2020, 08:28:56 AM »
I got a box of 50- 1/2"x 5" hot dipped lags for far less than any regular supplier on ebay. Same for Simpson-strongtie angle brackets they are holding now. Not a source for a commercial builder with valuable time though logical for old farts like me...
stihl cylinder metal base gasket
Started by bluejean on Chainsaws
Last post May 27, 2020, 06:59:05 PM
by Old saw fixer
Post on mudsill vs. on post base
Started by kodl on Timber Framing/Log construction
Last post October 12, 2018, 07:48:16 PM
by Don P
Hinged Post Base
Started by Zeke on Timber Framing/Log construction
Last post March 28, 2005, 12:27:32 PM
by Jim_Rogers
post and beam metal brackets
Started by shad on Timber Framing/Log construction
Last post January 24, 2010, 04:05:30 PM
by Hilltop366
