Dynamic Green Products Inc.
Author Topic: Need some ideas for square cutting 6x6's  (Read 748 times)
Offline Redhorseshoe
« on: November 29, 2020, 09:44:27 PM »
I mentioned in another thread I cut a lot of 6x6 fence posts.  I need a better way to trim the ends square than a chainsaw.  It takes forever and isn't as neat as I'd like.  I saw another guy with a chop saw that uses like a 20" blade and works really well.  I don't even know what that knid of saw is called though.  I'm thinking of maybe modifying an old buzz saw but don't like how dangerous they seem.  Any ideas how to speed and tidy up this process?
Offline Southside
    • White Oak Meadows
Re: Need some ideas for square cutting 6x6's
« Reply #1 on: November 29, 2020, 09:58:21 PM »
A jump saw would do what you need and do it very well, guess it depends on how many you need to cut to verify the investment.
White Oak Meadows
Offline miro
« Reply #2 on: November 29, 2020, 10:00:26 PM »
That 20 in blade sounds too violent and would need a large power plant of some sort.
How about a swinging chainsaw jig. The pivot is fabbed onto the bar with a "saw table" to hold the 6x6's square to the bar.
Since it's only cutting 6x6's , an electric chainsaw might be quieter and easier to manage.
I assume that you are cutting softwoods - don't think anyone wants walnut or maple fence posts
Offline Don P
    • Calculator Index
« Reply #3 on: November 29, 2020, 10:19:31 PM »
Hitachi makes or made a 15" miter saw, not sure if that would make it through. A Makita 16" skillsaw will do 6-1/4". A chainsaw paper cutter type jig on a roller table with a fence would give square cuts but a little rough.
The future is a foreign country, they will do things differently there - Simon Winchester
Offline Old Greenhorn
    • Woodsman Forest Products
« Reply #4 on: November 29, 2020, 10:24:46 PM »
Look into the makita timber saw, better yet do a search here on the forum. There is another saw similar to it that some folks really like but I can't recall the name. There have been several discussions on them here. That makita, I can tell you cuts off 6x10 hardwood beams with a beautiful finish. I love the thing.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, yet.
Offline Larry
    • Copas Sawmill
« Reply #5 on: November 29, 2020, 10:28:32 PM »
I bought an old Dewalt ras at auction for $85.  It was a GE model and would swing a 16" blade but I heard they could be fitted with a 20" blade that had a 6" depth of cut.  I restored the saw and sold it to a pallet shop because it took up too much space in my shop.
I was in an Amish shop long time ago that had one like I just described.  They had modified it with a hydraulic feed so one didn't have to pull the saw.  Lumber was fed on live roller tables.  The operator set on a stool and operated a couple of hydraulic controls.  They were using it to defect wood flooring.  It was cheap, fast, and efficient.
If ya have the coin a new Original ras should easily handle the chore.
https://www.elitemetaltools.com/tool-shop/products/original-saw-company-20-super-duty-radial-arm-saw-3553?sku=3553
Old swing saws are around that would also do the job.....dangerous but I suppose one could safeguard it.
Offline Don P
    • Calculator Index
« Reply #6 on: November 29, 2020, 10:35:30 PM »
I worked in a couple of shops that had the big deWalt, I like the idea of hydraulics or even a damper on it. They always felt like people eaters.
« Reply #7 on: November 29, 2020, 10:57:09 PM »
What I'd like is a stationary saw on a table with length marks/stops.  Slide the post up, square one end, slide a bit more, trim to length.  I've also been contemplating the chainsaw jig with a battery chainsaw.
Offline Bindian
  • Gender: Female
« Reply #8 on: November 30, 2020, 01:52:58 AM »
Square top fence posts?  Down here we cut cedar posts on an angle to help water run off faster.
hugs,  Brandi
Mahindra 6520 4WD with loader/backhoe and a Caterpiller E70 Excavator.  My mill is a Woodmizer LT40HD Wide Diesel. An old Lull 644D-34 called Bull
My Hero is Johnny Jett
Offline mike_belben
  • Pulp Friction
« Reply #9 on: November 30, 2020, 07:44:12 AM »
I angle cut posts too.. They rot a dish in the center otherwise.
A prazi beamcutter attachment on a wormdrive cicular saw, or a chainsaw chopsaw will do it.  The chopsaw will be much faster than the prazi.  You can drill a hole in the bar with carbide on a drillpress.  About 2 minutes at a machine shop.
Revelation 3:20
Offline mike_belben
  • Pulp Friction
« Reply #10 on: November 30, 2020, 07:48:18 AM »
A cheap chinese metal cutting horizontal bandsaw with a wood blade will also do fine and leave a perfect finish.  Blip the corners with a palm sander if needed.
Revelation 3:20
Offline Don P
    • Calculator Index
« Reply #11 on: November 30, 2020, 08:13:30 AM »
Mikes chainsaw is what I was thinking.
Check out the pic of these swinging sawstops, you can put as many as you need along the bar and set them to your cut lengths. Roll along till you get to the one you need , push an and up to the stop, the others swing out of the way.
Tables for Whirlwind Saws (whirlwindparts.com)
Offline mike_belben
  • Pulp Friction
« Reply #12 on: November 30, 2020, 09:45:56 AM »
The link isnt taking me to any product @Don P
Revelation 3:20
Offline moodnacreek
  • Sawin by the notches
« Reply #13 on: November 30, 2020, 12:59:12 PM »
Did anybody mention the old swing saw? That's the only way I have seen it done.
Offline Larry
    • Copas Sawmill
« Reply #14 on: November 30, 2020, 01:30:16 PM »
Those things scare us bandmill sawyers! :D
I have seen lots of them in circle mills.  You got one?
angry
Still not cutting SQUARE!?!?!
Started by quadracutter222 on Sawmills and Milling
Last post January 31, 2019, 10:40:27 PM
by quadracutter222
Cutting square with LT28
Started by jrkimroxie on Sawmills and Milling
Last post January 09, 2011, 11:54:34 PM
by MartyParsons
cutting log ends to square
Started by michaelvp on Timber Framing/Log construction
Last post September 17, 2009, 02:06:48 PM
by Doug_D
Cutting a square hole in a board
Started by Osric on General Woodworking
Last post September 10, 2007, 05:53:05 PM
by metalspinner
