Author Topic: Is there are market for Quaking Aspen in northern NH  (Read 1052 times)
Online peakbagger
« on: March 19, 2021, 12:19:27 PM »
My wood lot has a section of woods with a lot of tall straight popples that I think are quaking aspens. They are definitely dominant and are shading out a predominately sugar maple stand underneath. They are in the 16" to 30" range DBH. I have dropped a few to play around with on my friends sawmill. There are no chipboard mills anywhere nearby that I aware of. I do not use if for firewood as I have plenty of beech that needs cutting out. Over the years I havent heard of much of market for it, the pulp mill in Berlin I worked for restricted the percentage of popple in loads to the mill t small percentage. Other folks have told me that there is market for logs. Its steep lot so getting logs out of the woods would not be fun.
So if there a market for these logs in northern NH?
Offline VTKubotaM6800
Re: Is there are market for Quaking Aspen in northern NH
« Reply #1 on: March 19, 2021, 12:30:53 PM »
Following this thread. I also have lots of straight popple here in Central VT and have found no good use for it except building rotting log piles. It makes terrible firewood. They also uproot easily so I find fallen ones on my property after most windstorms, not a good situation in the eventual sugar woods.
M6800, Farmi JL 601 winch, Titan BX26S chipper, Pronovost P-860 snowblower, Woods 9000 backhoe, Stihl MS362C-M
Offline PoginyHill
  • Gentleman logger
« Reply #2 on: March 19, 2021, 01:19:57 PM »
I know it's not hard maple or beech, but I've found popple to be decent. Although I have an outdoor wood boiler, so the less energy-dense nature of it is not all that bad. It has about the same BTU content as red maple or white birch. Still better than almost any softwood. I have some larger popple, but most are under 10". I've had some larger stuff sawn for 1" lumber. Good utility lumber. I did board and batten siding on a shed several years ago with it - and happy with it. I'll also be interested to see what markets might exist. I'm not aware of anyone in northern Vermont buying it.
Kubota M7060, Cat E70B, Case 310, 750 Grizzly ATV, Wallenstein FX110, 84" Landpride rotary hog, Classic Edge 750, Stihl 170, 261, 391
« Reply #3 on: March 19, 2021, 02:55:26 PM »
I'll have to give it a try in my new boiler. I've tried it in my wood stove before and while it splits super nice, it seemed like it took forever to dry and kind of turned to dust instead of coal when it finally did burn. Maybe the boiler will be a good way to get rid of it.
Offline sprucebunny
  • Gender: Female
« Reply #4 on: March 19, 2021, 05:39:21 PM »
I had some logging done on my land in Coos county a couple of years ago and at that time, there was a good market for quality poplar.
I see it for sale at the big box stores as 'whitewood' for interior trim.
Offline g_man
« Reply #5 on: March 19, 2021, 07:22:53 PM »
I don't know how far you want to go but Northeast Timber Exchange has a listing for Aspen Saw Logs - Sounds like you have some big stuff.
http://northeasttimberexchange.com/wp-content/uploads/2021/03/NTE-Saw-Logs-Prices-and-Specs-March-1-2021.pdf
gg
Online peakbagger
« Reply #6 on: March 19, 2021, 08:22:56 PM »
Thanks, sounds like its not worth the hassle. I may just girdle the ones that are are not readily accessible and saw some up for boards.
Offline Firewoodjoe
  • Im getting old
« Reply #7 on: March 19, 2021, 08:30:31 PM »
Just split it and burn it. Donít let it sit to long. We burn lots of it. Hot but fast. Or better yet saw it. We log it all the time. Itís my favorite to production log. Makes good lumber. Easy to work when green and hard when dry. But keep it dry cause it will rot. Like if grass touches it when used for siding. Even log cabins are built from it.
Offline KEC
« Reply #8 on: March 19, 2021, 08:44:54 PM »
Sprucebunny, Aspen is not the same as whitewood. Whitewood is the same as Yellow Poplar or Tulip.  As far as whether there is any market for aspen, the state forestry department should have that info.
Offline snowstorm
« Reply #9 on: March 20, 2021, 07:39:05 AM »
paper mill in Rumford always bought  it. when the jay was buying wood they could not get enough of it it was used to whiten the paper
Offline Clark
« Reply #10 on: March 20, 2021, 12:07:24 PM »
PoginyHill - If youíre talking about BTUs/pound then yes. All wood is within 10% of the average when it comes to that measurement. BTUs per cord? Quite a difference between birch and aspen.
Clark
SAF Certified Forester
Offline KEC
« Reply #11 on: March 20, 2021, 12:13:10 PM »
If I remember correctly, in the 1970's, the mill I worked for had a woodlot that they cut which had a lot of aspen. I think it ended up at the then Charmin Plant (later Proctor Gambel plant) in Mehoopany, Pa.. Someone mentioned that they liked it for making paper. That plant made pampers and maybe paper towels and TP. I hauled chips to that plant and once got a chance to see their log chippers. Two chippers, next to each other taking at least 16" diameter logs up to 22' long and each chipper with a 1200 HP electric motor. When a log went in you could hardly detect any reduction in the rpm's.
Offline Bruno of NH
« Reply #12 on: March 21, 2021, 07:07:50 PM »
It's to bad it's in the north country.
I buy poplar, popple, aspen logs
Saws nice , but can move on the mill.
I sell lots of it for framing lumber , roof strapping and nice clear 1" and 1"1/4 boards.
It will be one of the woods I will dry in the kiln when built.
Offline cutterboy
  • Sometimes trees fall where they want to.
« Reply #13 on: March 22, 2021, 07:11:21 AM »
I also saw and sell Quaking Aspen. It's a slow seller but steady. I have two steady customers who love it but they are hobby wood workers and only buy small amounts.
Offline PoginyHill
  • Gentleman logger
« Reply #14 on: March 22, 2021, 08:29:39 AM »
Clark
From what I understand aspen is about 18.2 MMBTU/cord, white birch 20.2, and red maple 18.6. Softwood is 14-16MMBTU/cord and the traditional hardwood firewood in the mid 20's MMBT&U/cord. Yellow birch is 21.5 and black birch around 24.
Offline Clark
« Reply #15 on: March 22, 2021, 09:51:57 PM »
Now Iím confused. Originally I was going on the fact that A) no one burns aspen up here B) lots of people burn birch and C) dry birch seems heavier than aspen.
I had looked aspen up in one table and it showed 14.7 million BTUís per cord. Every other table lists the 18.2 you show. I looked up the density (which is directly related to BTU content in wood) and aspen is 26 lb/ft3. Paper birch 38 and white oak 47. BTU content according to my original chart is 14.7, 20.3 and 25.7 respectively. Those values seems to fall very much in line with density. I donít know why so many tables list aspen at 18.2 unless there is something I am missing.
Clark
Offline cutterboy
« Reply #16 on: March 23, 2021, 07:22:31 AM »
Over the years I have burned a lot of white birch and red maple and a fair amount of aspen. (quaking) It seems to me that red maple and white birch last about the same amount of time in the stove but aspen does not last as long. But I will say that DRY aspen burns well and gives off a nice heat. I'm happy with aspen if I'm in the house and can feed the stove often, but if I'm out of the house for hours, I want oak or hickory or ash.
Offline PoginyHill
  • Gentleman logger
« Reply #17 on: March 23, 2021, 07:32:13 AM »
I wish I knew a good answer. I don't even have good anecdotal information. I've only burned softwood and aspen in my outdoor wood boiler, and it's always mixed with other species. I do believe that aspen dries more slowly than other species, maybe that's part of people's experience with it: comparing somewhat green aspen with dry wood of other species.
Offline g_man
« Reply #18 on: March 24, 2021, 08:25:20 PM »
The old table I have lists aspen at 12.5 million BTU per cord and W Birch at 18.9 which about matches my experience. I burn quite a bit of w birch and red maple but not much aspen.
gg
Offline PoginyHill
  • Gentleman logger
« Reply #19 on: March 25, 2021, 08:05:25 AM »
Interesting there would be such different information out there from reputable sources. I'll have to do an experiment (probably have to wait 'til next winter) with a OWB load of 100% aspen vs. red maple or white birch. I cut plenty of popple this winter for next year.
But I'm still interested in the market for popple logs in northern VT or NH.
Quaking Aspen
Started by Mikeysmill on Sawmills and Milling
Last post March 04, 2006, 09:50:51 AM
by logwalker
Quaking Aspen
Started by GAV64 on Sawmills and Milling
Last post October 03, 2003, 11:19:29 AM
by ronwood
quaking and bigtooth aspen
Started by GAV64 on Timber Framing/Log construction
Last post October 17, 2005, 12:22:00 PM
by beenthere
Lots of ~30-35" x 80-100' Quaking Aspen, what to do with it?
Started by kiamori on Sawmills and Milling
Last post November 01, 2020, 09:38:08 AM
by Stephen1
