Author Topic: lucas mill gearbox overheating  (Read 1863 times)
Offline Baldywoodfreak
« on: March 21, 2021, 08:06:46 PM »
Hi all
Been using my brothers mill for the past few weks and it seems the gearbox is getting real hot while milling with the circular blade. The gearbox oil had gear oil , guessing 90w , and I replaced it with dextron 4 at the suggestion of the Lucas mill tech support.  But it is getting very hot now. Im wondering if it is on the verge of failure with it heating like that. Im also thinking of draining the oil and putting in 90w gear oil to see if that makes a difference. Any thoughts?
Offline Don P
    • Calculator Index
Re: lucas mill gearbox overheating
« Reply #1 on: March 21, 2021, 08:21:11 PM »
We run 90W in my partner's. Only thing I can think if you don't have a bearing going out is, are the belts overly tight?
The future is a foreign country, they will do things differently there - Simon Winchester
Offline Gearbox
« Reply #2 on: March 21, 2021, 09:11:06 PM »
did you use a temp gun . I have said many times the hot water out of your tap maxes out at 120 degrees F . Oilcan run all day at 140 to 150 . hotter than that you have a problem . Angle gear boxes don't hold much oil and almost always run hot .
« Reply #3 on: March 22, 2021, 01:11:03 AM »
I haven't checked the temp as of yet. I will do that. Just changed the belts and they are not to tight. THX for all the replies. Ill post when I find anything new.
« Reply #4 on: March 22, 2021, 01:23:50 AM »
Just one more thought Id like to throw out there. I am wondering if the slabber, which we used to slab some 36 - 48 " wide pine logs, puts way to much strain on the gearbox. Especially if the chain starts getting dull. Seems with a sharp circular blade it is no problem but the slabber has me thinking.
Offline Don P
    • Calculator Index
« Reply #5 on: March 22, 2021, 07:27:12 AM »
I wouldn't think so. I've not slabbed pine but have slabbed big hardwoods with it.
Lucas gearbox, and LUCAS SLABBER DRIVE HUB pictures wanted
Started by shelbycharger400 on Sawmills and Milling
Last post September 04, 2011, 11:32:02 PM
by shelbycharger400
Lucas 618 gearbox gasket
Started by chep on Sawmills and Milling
Last post August 15, 2012, 07:58:41 AM
by chep
Lucas Gearbox Rebuild
Started by Hokiemill on Sawmills and Milling
Last post September 06, 2008, 11:09:06 PM
by brdmkr
Swing mill gearbox
Started by bandmiller2 on Sawmills and Milling
Last post November 28, 2007, 06:04:48 AM
by bandmiller2
