Author Topic: winch trouble  (Read 541 times)
Offline loggerman1959
winch trouble
« on: March 25, 2021, 06:02:05 PM »
I have a gearmatic 19 winch that is having trouble freespooling . When I lift the handle the spool unwinds freely , but won't stay free . It locks back up . I relift the handle and it will freespool again for a bit then locks up again . Anyone ever run into this before ? Any advice would be appreciated.
Offline bushmechanic
  • Someone else has it worse than you.
Re: winch trouble
« Reply #1 on: March 25, 2021, 08:13:23 PM »
Sounds like you have air in your release cylinder. Bleed the line to the top of the winch.
Offline Ed_K
Re: winch trouble
« Reply #2 on: March 26, 2021, 07:39:44 AM »
 Have you changed the brake pad recently? I'm fighting that right now as the replacement is 3/8" instead of 5/16". I've got shaved down some with a rasp but still need to wear it in before it'll work right. Then again after rereading your post is the lever staying in place for free spool when you let go of the handle, if not the hydraulic lines may be crossed.
Ed K
Re: winch trouble
« Reply #3 on: March 28, 2021, 03:01:37 PM »
Yes the lever stays in place , the winch just locks up after a few seconds of freespool
Offline Satamax
  • Living in Absurdistan!
Re: winch trouble
« Reply #4 on: March 28, 2021, 10:29:10 PM »
Air, or a tiny  leak. I'm no expert. I'm just working on mine.
Offline Ed_K
Re: winch trouble
« Reply #5 on: March 29, 2021, 07:03:39 AM »
 Try loosening the 3/8-24 allen screw on the top of the winch. They most times have a spring between the brake band and the screw.
Re: winch trouble
« Reply #6 on: March 31, 2021, 09:23:56 AM »
Thanks for all the input
timberjack 225 winch trouble
Started by Timberjack Tom on Forestry and Logging
Last post July 05, 2011, 07:03:04 PM
by smwwoody
Franklin q80 winch trouble
Started by Ideker2010 on Forestry and Logging
Last post January 18, 2020, 12:22:02 PM
by jgoodhart
deere 440a winch trouble
Started by thumper on Forestry and Logging
Last post April 28, 2015, 11:44:51 AM
by grassfed
gearmatic winch 119 trouble bleeding clutch
Started by Pa.Logger on Forestry and Logging
Last post July 09, 2017, 08:48:51 PM
by coxy
