Author Topic: Wood mizer lt30 help and information please  (Read 440 times)
Offline norris13052006
« on: April 03, 2021, 11:53:57 AM »
Ok so being new to all this I just bought this setup it had been sitting a few years. So of course the hydraulic blade tensioner is leaking and needs rebuilt. Has anyone sourced the rebuild parts from other places than wood mizer? Looking for suggestions on a log Turner for this thing as well
Offline GAB
Re: Wood mizer lt30 help and information please
« Reply #1 on: April 03, 2021, 01:40:28 PM »
Concerning the W-M tensioner rebuild I got my parts from W-M.  I'm not aware of any other supplier.
Concerning the log turner issue, one who I think could help you is @pineywoods, @YellowHammer is my second choice.
Note: When rebuilding a W-M tensioner for the first time allow more time than you think it should take.  My experience is that there is a very steep learning curve.
GAB
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #2 on: April 03, 2021, 03:28:29 PM »
I built a nice claw turner with an electric winch, it worked fine.
YellowHammerisms:
Take steps to save steps.
If it won’t roll, its not a log; it’s still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, they’re burned, and you can’t fix them.  Don’t burn the cookies.
Offline pineywoods
« Reply #3 on: April 03, 2021, 09:04:52 PM »
My claw type turner also serves quite well as a 2 plane clamp.
Search "home made hydraulics"
Offline 47sawdust
« Reply #4 on: April 03, 2021, 09:18:18 PM »
My LT30 came with a hand crank log turner.
I replaced the hand crank with a 12 volt winch that has a remote pendant. It works great.
Mick
« Reply #5 on: April 03, 2021, 09:58:31 PM »
Any pictures of ur log turners be much appreciated
Offline Southside
    • White Oak Meadows
« Reply #6 on: April 03, 2021, 10:28:11 PM »
If you own a WM mill, get WM parts.  They are very fair on prices and with consumables - belts come to mind - they actually have their own requirements which exceed the NAPA type options, ask me how I know.  Oh - and I am a farmer so Gorilla tape and bailing twine are normal solutions for me, but when it comes to the mills and support equipment, I just call them and stay money ahead.
White Oak Meadows
Offline 47sawdust
« Reply #7 on: April 04, 2021, 12:44:02 PM »
Factory manual log turner can be ordered from WM.
My 12 volt winch was originally mounted where the hand crank was.
I moved it to its present position when I added a hyd. loader and toe rollers.
Log turner to right of clamp, winch is now suspended from frame just to left of clamp.
Mick
Offline Brob1969
  • New Sawyer
« Reply #8 on: April 04, 2021, 12:48:57 PM »
I would sure love some more photos of this setup!  I would like to do something similar.
1990 Woodmizer LT40, 18 HP Briggs Twin II
1980 Ford 555 backhoe
1996 John Deere 4475 Skid-Steer
Offline Brob1969
  • New Sawyer
« Reply #9 on: April 04, 2021, 12:51:44 PM »
I just recently rebuilt the tensioner on my LT40.  It was fairly straightforward using the kit from Wood-Mizer. It was not terribly expensive and I wouldn't know where to start trying to source the part numbers otherwise.
Offline 47sawdust
« Reply #10 on: April 04, 2021, 02:22:54 PM »
Well you caught me at just the right time  :D.
Originally power was taken directly from the battery box with a Cole Hersee plug and receptacle.Hence the hole in the box.
Plug and receptacle are wired and available.
After adding hydraulics the winch is powered from the hyd control box via the contact strip.
This set up serves my purposes very well.
 <br
 <b
The winch is a 3700# warn, since discontinued.The pendant allows me to be right at the log when turning.
r><
br>
Important to unplug the winch before going forward if you use this setup. Grandpa Bonehead tried it more than once, slow learner
Mick
« Reply #11 on: April 04, 2021, 08:30:43 PM »
I'm going to finish checking everything out before I order anything.. I also had a big black walnut gave to me but going to mill some red oak before I even think touching it... I have a ear cracked off the gear reduction box for the lift still works... But going to look into a spare anyone have one they done need
Offline Brob1969
  • New Sawyer
« Reply #12 on: April 05, 2021, 09:01:37 AM »
 <br
 <b
r>(Image hidden from quote, click to view.)<
br>
Thanks for the photos!
I believe I will do something similar.  This looks like a good setup.
Offline Crossroads
  • let’s make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #13 on: April 05, 2021, 10:22:56 PM »
I built the pineywoods claw turner and it was a game changer.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
Wood Mizer lt30
Started by moandrich on Sawmills and Milling
Last post May 10, 2012, 09:10:45 PM
by moandrich
Wood-mizer LT30
Started by 60lp on Sawmills and Milling
Last post January 30, 2014, 11:21:43 AM
by eric3793
Wood Mizer lt30 gt Charging Problem
Last post September 03, 2012, 09:30:38 AM
by trapper
Wiring Wood-Mizer LT30 trailer lights
Started by DouginUtah on Sawmills and Milling
Last post September 25, 2005, 05:11:14 PM
by maple flats
