Help with hydraulic fitting
Started by Dan_Shade, June 25, 2021, 07:08:04 PM
Dan_Shade
I "upgraded" the disconnect on my LT-40 several years ago, and just bought another tank.  I'd like to find another of these adapters.
I can't find what it is in my files...
lots of dull bands and chains
Dan_Shade
LeeB
Dan_Shade
I'm hoping someone may know the brand and/or style so that I can find a mating one.
The o-rings are different in these from the others that I looked at.
terrifictimbersllc
I've attached the parts you've shown  from woodmizer for the LT40 Super/70 Super plastic diesel tanks.
The second one item 5 is the female that connects to the hose.  The first one item 4 goes into the tank.
The first number for each is the wwomizer part number.
Dan_Shade
Are the ones on the diesel engines metal?
I swapped out the factory ones because they would get stuck.
What I have is way better, I just don't know what I have.   ::)
moodnacreek
Just figure out your pipe thread size and buy a new quick disconnect at a farm store.
terrifictimbersllc
Quote from: Dan_Shade on June 25, 2021, 08:54:04 PM
They look exactly like the parts you showed in your post above. I've been using these for about 20 years now and they don't get stuck.
Dan_Shade
Thanks, that's probably what I have...
Dan_Shade
mike_belben
Praise The Lord
Chuck White
You can also get those quick disconnect fittings from places that sell boating supplies!
maple flats
I've had good success taking a fitting or hose to a place that specializes in hydraulics and universal joints. They seem to be able to match up anything.
For hydraulic couplers by far I prefer flat face couplers, they just work far better than what you get at most farm equipment dealers, unless they are also Bobcat dealers. I own nothing made by Bobcat, but their couplers excell.
maple flats
In fact I just added hydraulics to the thumb on my excavator. I just removed a hose in the circuit I'm tapping into and a hose where it attaches to the excavator. Turned out a good thing, the machine had both SAE and Metric connections, I didn't realize that when I started. Everything now is SAE except the connections where it taps into the excavator, those have metric ends on the hoses that tie into the excavator hydraulics.
Now I just need to wait 1 more day, until a fuse holder arrives tomorrow.
My excavator will then have one valve that can do either of 2 functions as needed. It has an electric solenoid valve, to switch between boom offset and hydraulic thumb.
The hydraulics place knew exactly what I needed when I showed them the parts I had and told then how long each of the hoses needed to be. They made them to fit my equipment.
