Author Topic: Mini-Split heat pump for room in pole building?  (Read 1967 times)
Offline gspren
« on: August 13, 2021, 07:41:56 PM »
  There's some talk about mini-splits in another thread but I have a different situation so I'll start my own. In the back corner of my new pole building I plan to build a 12'x24' room that will be my man-cave hangout with a workbench and just a place for tinkering and hiding from "her" during the day. No water to freeze or need to heat/cool all of the time but heat to mid 60s or so in winter and cool to mid 70s in summer would be nice, in extreme weather I could just stay in the house. Is a mini-split practical?
Offline farmfromkansas
Re: Mini-Split heat pump for room in pole building?
« Reply #1 on: August 13, 2021, 07:48:51 PM »
Mini split systems are supposed to be very efficient. Think I would double your shop space before you get it done and find it too small. Would affect your heating cooling if you have to add space.  Wood stove is great in winter, and you can get a mini split that is just AC.
Offline gspren
« Reply #2 on: August 13, 2021, 10:19:29 PM »
This is not for the main shop, just a room within, the main building at 46' x 64' will be the "shop" for both storage and working on stuff. I want an easy to heat/cool room for taking a break or just messing with little stuff like cleaning guns and sharpening chains, etc.
Online metalspinner
« Reply #3 on: August 13, 2021, 11:27:00 PM »
Is it practical? What's your other option? A window unit?
I am in the same situation as you. My pole building is 40x60 and I made a room 10x40 that I'm installing a mini split for both heat and air. Its supposed to be very efficient. We'll see, I guess.
The one I'm having installed is good for up to 600sqft. But your space is half that.
Offline SwampDonkey
  • Large Tooth
« Reply #4 on: August 13, 2021, 11:39:37 PM »
If you're after AC mostly a modern AC unit in a window is way cheaper to buy and cheap to run. I have an 800 sq foot one, as big as you can get on a 110 outlet. And doesn't add $40 to the electric bill per month. A dehumidifier takes more juice to run continuous. Up here in winter at below zero a minisplit will really struggle compared to a wood stove. We had a large heat pump for the other house, they install an electric furnace along with it. $10,000 later. That should tell ya something. I never want to see another one again. :D
No amount of belief makes something a fact. James Randi
Online btulloh
« Reply #5 on: August 14, 2021, 12:00:15 AM »
Ive got a 12x24 standalone building insulated with R13 batts in ceiling and walls and its pretty tight too.  Small window unit mounted in a cutout in the wall and a simple strip  heater with a fan that mounts between studs.  No problem getting it warm or cool.  The a/c is one of the newer units and is really efficient. The strip heater is what it is, but it supplies plenty of heat for the space. 2000 watt if i recall. I just use that space for reloading and a few other things like that. Less than $400 in the combo, and hardly a tickle on the electric bill. Just occasional use, but in the summer Ill keep it around 80 and turn it down if Im going to be working in ther
HM126
Offline gspren
« Reply #6 on: August 14, 2021, 08:48:55 AM »
I'm considering different options, need to ask insurance people about wood stove wouldn't want to go through the work and expense of putting in a stove and then paying too high of a premium to use it. I've also thought of the window A/C mounted on one of my interior walls exhausting into the main shop with a bucket to catch condensate and a small propane heater. This will not be used every day, just occasional use.
Offline hedgerow
« Reply #7 on: August 14, 2021, 09:43:44 PM »
I like mini splits and have put a lot of them in. Mostly for upstairs in two story houses. Don't forget to give the PTAC units a look will be less than a mini split. I have installed a lot of them in your type of applications.
Offline peakbagger
« Reply #8 on: August 15, 2021, 05:44:33 AM »
Its good application, especially if its sealed up from the rest of the building. Costco sells units with precharged lines that have a good rep. No need to hire an installer.  Not as efficient as the name brand units but still a lot quieter and more efficient than a window unit. Where any minisplit has issues is much below 20 F. Yes it will put out heat but it has rough time heating up a cold space.
The tradeoff is they are not cheap compared to window unit but if you want heat hard to beat.
Online Al_Smith
« Reply #9 on: August 15, 2021, 08:14:41 AM »
I think for efficiency you have to factor in insulation and control of humidity for both heating and cooling .A little bit of insulation can save you a lot money over the long term .Otherwise you are just paying out a lot of fuel charges that could be avoided .For heating you might look into infrared heaters and just go with regular air  to air  air conditioning  for cooling rather than with the heat pump option which are not very good at temps below 40 degrees .
Online Al_Smith
« Reply #10 on: August 15, 2021, 08:38:21 AM »
I might add a little bit to the conversation .Recently my long term tenant on my rental passed away suddenly .Unknown to me the furnace plus the air conditioner were on the fritz .Somebody again unknown to me had replaced the blower motor and reversed the rotation .This threw the furnace into a high fire condition and cooked the compressor on the air . I had it figured out in about 10 minutes but it still cost me nearly $900 for a new 2 ton air unit .He had  two mini splits heating and cooling the house and never told me the problem for some reason .Plus the dehumidifier was out of commission and that caused a moisture problem in the basement which could have been prevented by a phone call .HVAC is not rocket science but it is  surprising the amount of people who have no idea of actually how it works .To get the most out of it you have to stay on top of it .---they  say a stitch in time saves nine----
Offline scsmith42
    • Whispering Pines Farm
« Reply #11 on: August 15, 2021, 08:28:28 PM »
I have two mini-split heat pumps in use here on the farm.  One is in a building that measures around 14' x 40', and the other is in a log cabin that measures around 18' square with a 12' wall height.
The 14 x 40' building is used by my wife's non-profit Veterinary practice as the inventory building.  It has a Mitsubishi unit with a ceiling cassette instead of a wall mount.  It works great; is extremely quiet and very effective.  This building has a tankless water heater inside it along with a stacked commercial washer and gas dryer, and the minisplit keeps up even with the heat generated by the commercial dryer.  Mitsubishi M series mini-splits have one of the best reputations in the industry.  We used to use them when we had to build a cell site inside a commercial building and were too space limited for a standard split HVAC unit.  The Mitsubishi units were the only ones that would last in that environment.
The log cabin has a Pioneer unit.  I use this building as a tool shed and machine shop.  It too works well but is not in the same league as the Mitsubishi.  It takes longer for the Pioneer to recover if the door is left open, and it does not do as well heating in the winter as the Mitsubishi, but it's still acceptable.  However the Pioneer was a $1000 unit versus $3k for the Mitsubishi, so I'm willing to cut it some slack!
Myself and my farm hands did both installations.
Below is the log cabin installation.
Here is the condenser unit mounted on the back side of the cabin.  I painted it brown to blend in better and used wall mount brackets that are designed for mini-splits.  The box covers where the condensate drain and refrigerant lines exit the cabin wall.  The lower pipe is the drain; the upper pair is the refrigerant.
Here is a pic taken inside the cabin.  In addition to keeping the cabin nice to work in, the dehumidification features of the mini-split prevent rust build up on my tools and tooling, which was a significant factor in replacing the previous window AC unit with a mini-split heat pump.  The window unit was not cutting it in terms of dehumidification inside the cabin.
Both units are highly energy efficient, and a mini-split would be my first choice for the situation that you're in.  By all means insulate the room as well as you can; you will reap the rewards in terms of comfort and energy savings.
Tom's 3638D Baker band mill
Offline John Mc
« Reply #12 on: August 15, 2021, 09:14:18 PM »
Has anyone seen a cold climate heat pump that will allow a heating set point down around 45˚F or so? My wife has a 24'x26' workshop that get used only occasionally in the winter. Most of the time all we need is to keep paint and other supplies from freezing.
I realize that recovery time isn't exactly the greatest with most heat pumps, but we could always supplement with a space heater if we needed to bring things up quickly.
When I looked a couple of years ago, all we could find were units with set points down to around 60. That's a whole lot warmer than we need to keep the place most of the time.
Online beenthere
« Reply #13 on: August 15, 2021, 10:07:09 PM »
Use a mercury switch thermostat and mount it at an angle so the set point is changed to the degree that you want. Have my shop heater set at 45 for the heat to come on.
Offline John Mc
« Reply #14 on: August 15, 2021, 11:11:02 PM »
I thought most minisplits had the thermostat built-in. If you can use an external thermostat with them, that's a great idea, though it may complicate using the AC in the summer.
Offline Texas Ranger
  • Texan, by God and by choice.
« Reply #15 on: August 15, 2021, 11:49:28 PM »
I replaced two window units with a split unit in office, 900 sq ft of not heavily insulated slab and metal building, about a year ago.  The split unit is more efficient and provides both heat and cool.  Unit cost $2300 installed, replaced about $800 worth of window units.  Electricity cost went down, humidity went down, and it is quite.  The split units come in different sizes so you can more or less fit your needs.  It has a hand held remote to handle the program, a hand held thermostat if you would.  Mounts on the wall in a holster.  It basically runs an internal fan 24/7 that you can barely hear, out side unit cycles on and off and is not heard inside the building.
I am satisfied it works better and more efficiently than the window units.
Will it pay for itself?  At some point.  But dryer office and uniform temperature is a good results.
Offline scsmith42
« Reply #16 on: August 16, 2021, 06:05:40 AM »
My Pioneer included a remote control with thermostat. The Mitsubishi has a wall mounted thermostat.
Offline gspren
« Reply #17 on: August 16, 2021, 08:44:41 AM »
I'm fairly certain I will go with the mini-split, room will be under 300 Sq Ft and will be easy to insulate. I am more concerned with cooling than heating but I do want both, there will be times in winter where it isn't used for a few weeks while we are away and then when we return I could use a portable propane heater for a few hours at start up.
Offline John Mc
« Reply #18 on: August 16, 2021, 08:52:07 AM »
One thing to keep in mind on the portable propane heaters: If a propane heater is not vented, it adds a lot of moisture to a room. If you are just running for an hour or so, or if you have some kind of outside air exchange/ventilation it may not be a big deal. We found out the hard way just how much moisture it can add when we heated my wife's very tightly sealed shop for several very cold days. The walls were dripping.
Offline gspren
« Reply #19 on: August 16, 2021, 08:59:38 AM »
If and when I used the propane it would just be a kick starter to get the room up in the 50s then the mini split would be used alone. I guess next question is size and brand recommendations.
need to heat a warming room that will heat 2 drums of product
Started by adamant on Firewood and Wood Heating
Last post November 29, 2015, 07:52:05 AM
by doctorb
HVAC Mini split system and Trombe wall
Started by OneWithWood on Alternative methods and solutions
Last post November 01, 2012, 01:30:02 AM
by John25mm
whats your heat pump kwh usage?
Started by semologger on General Board
Last post February 10, 2013, 11:19:23 AM
by Al_Smith
Electrical question - heat pump/airconditioner
Started by warren46 on General Board
Last post October 22, 2016, 03:54:35 PM
by Larry
