Author Topic: advanced setworks troubleshooting 1600tk  (Read 299 times)
Offline mpcolcla
  • Member*
« on: September 10, 2021, 12:36:39 PM »
Set Home Stuck on 1"
Everything was working fine, manually adjusting height using 'set home' button for each cut. Was cutting a very large in diameter log, maxed out height of mill. Reset 'set home' button display, 1 inch. Then my display was stuck on 1 inch when manually adjusting height up and down. All movement was with hydraulic handle.
Checked all wires for corrosion, opened control setworks box, everything looks fine and in place. Opened encoder box and checked cannon plug, everything looks good there as well. Is there anyway to test if the encoder box is working properly?
Offline Larry
    • Copas Sawmill
Re: advanced setworks troubleshooting 1600tk
« Reply #1 on: September 10, 2021, 01:34:06 PM »
Call TK.
A couple of weeks ago my setworks was intermittent.  Talked with Mike and he gave me a laundry list of things to check.  Turned out my problem was a broke fuse wire (not burnt).  Quick fix.
Welcome to the forum!
Offline ladylake
« Reply #2 on: September 10, 2021, 03:47:20 PM »
 Could be encoder trouble, did you make a cover so the exhaust doesn't blow on the encoder when the head is way up.  Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
WM troubleshooting
Started by woodmills1 on Sawmills and Milling
Last post February 11, 2004, 02:34:26 PM
by Stump Jumper
Husqvarna 61 Troubleshooting
Started by blinkstudio on Chainsaws
Last post May 19, 2021, 09:41:57 PM
by sawguy21
carriage troubleshooting
Started by Mikefults on Sawmills and Milling
Last post December 29, 2014, 03:05:11 PM
by slider
Mill Troubleshooting
Started by SW_IOWA_SAWYER on Sawmills and Milling
Last post April 24, 2020, 08:53:05 PM
by DPatton
