Whatcha Sawin' 2022 ??
Started by Magicman, December 31, 2021, 09:58:57 PM
firefighter ontheside
I have heard about cypress having silica, but never that ERC has it.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
   I also did not know cedar had much silica. The ones I get are pretty small and cut real easy. I rarely get anything as nice as one Lynn posted above. Often the customer wants it in thin strips like 1/2" or so. I usually saw it through and through then stand it up and saw the flitches in 1" drops till I get a "pretty clean" edge then flip and edge the other side. If the customer wants it cleaner (and thinner) I'll keep flipping and keep edging till he says stop.
   I do sometimes have problem with the fibrous bark on cedar stopping up my sawdust chute. (I have not removed my fingers in there like some, un-named members have done). I do find cedar seems to help clean up my bands. Buckeye also cleans them real good.
there is some in the bark, but even the wood looks like it has glitter in it if you look.
SYP 2X12's with the side lumber being 1X6's & 2X6's.
Eleven more logs to go.  They are very nice so they should make a whack of 2X12's.
shelby78
Quote from: Walnut Beast on June 12, 2022, 09:03:52 PM
Looks great!! How is the performance of your mill cutting the wider crotch stuff?
Walnut up here seems to saw real easy. Uber flat straight or crotch. My sharpener guy is good though.
Loaded up an ugly sycamore log to quarter saw last night and sawed it this morning when cool.  As ugly as the log was I was surprised to get some good looking boards out of it.
Back in the shop by 10am where I spent the rest of the day.  Outside 93 degrees with a  heat index of 106.
Walnut Beast
Looking good Larry! Sell that bad boy and treat yourself to the new wider frame and cut a full 38" 💪
78NHTFY
Managed to get to 3 of 13 logs from the walnut I cut recently.  Slabbed one log into 6 pcs live edge 9/4 x 10'.  Sticker pile is 10 rows high!  Easy lifting for the Takeuchi TL 150.... Now for the tough part: leave to dry; try to sell; make something out of them for myself/family?  One thing for sure, I HAVE to get my cordwood cut/split/stacked ASAP, 'cause I can't afford heating oil at present prices! All the best, Rob.
If you have time, you win....
Walnut Beast
Nice! It's a good time to peel the bark off. Some light hammer whacks on the bark and peels right off
Walnut Beast
Quote from: fluidpowerpro on June 12, 2022, 07:39:20 PM
Saturday cut some boxelder logs a friend gave me last fall. Not sure what I'll do with the wood. More so just wanted to cut it because I have not cut any before. Lots of red stripes like I expected from seeing it here on the forum. Today cut up a red oak into 8/4 trailer decking.
Been really eyeing my boxelder and thinking about your eye candy! There is quite a few along my creek
fluidpowerpro
It cut really easy and was fun to see what was inside. I'll find out if it will dry straight. I read up on it after and I guess people use it for turning. Had I known ahead of time I would have cut some into turning blanks although someone could still glue the 4/4 together and then turn it.
Change is hard....
  For those of you have cut it, how does that color hold up in the boxelder? Awful pretty stuff!
boonesyard
It's never as bright as when you first open it up, dulls when it dries. But as soon as you plane, joint and finish it, the color comes to life again.
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
My first job after "dry dock".  1920bf of mostly 2X12's with 1X6's & 2X6's side lumber.
My next job (depending upon the customer getting help) may be starting tomorrow and will also be SYP framing lumber.
EDIT:  I talked to the customer last night and we will not saw until next week.  Hot as it is, I am glad.  ;D
Hackeldam Wood Products
Edged some dry pine boards for the floor of my planer shed build.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Ford 340 Backhoe
Ljohnsaw
Had a plan but switched midway so not optimal result.  Took this:
and made these (1@8x12 and 5@5x9):
and this (3.25x25x17' and 5x6)
and a few other side planks and girts size stuff.
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Resonator
Cuttin' the curves. ;D
Best repeat customer and his wife wanted benches for around the campfire. So he got a piece of pine from a pile that was destined for OWB fuel, and brought it over to saw. I cut some about 2 1/2" thick slabs out of it, and I found it worked best to face the curve in towards the backstops to get every inch of cut width. Not sure if it was a log or a limb, so we'll cross our fingers and see how it dries. :D
Ljohnsaw
Quote from: Resonator on June 19, 2022, 11:29:07 AMNot sure if it was a log or a limb
If you apply YellowHammer-isms, it don't roll so it ain't a log! ;)
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Old Greenhorn
It may not roll, but if you put it up on edge it will rock and that has to count for something, right? ;D
Wlmedley
 Cut these out of a bent poplar tree last year.Made some pretty nice benches and a table top.Amazingly they stayed flat.
Wlmedley
Was cutting a couple pitch pines that were leaning and just a matter of time before they uprooted.In the process a dogwood tree was damaged badly.Hated to cut it but it wasn't salvageable.Decided to cut a few small boards out of it.Heard wood is really hard and makes good felling wedges.Going to give it a try. Anyone know any other good uses?br>
btulloh
Really good for handles on chisels, knives, etc.  excellent for carving mallets.  You can turn a nice billy club from dogwood. Never sawed into boards before.
HM126
There is something very satisfying in cutting down a tree and milling it into boards,
Here I am squaring the ends in one shot.
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
And then there they are. The floor for the planer shed. 1 1/4X8X8
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
Walnut Beast
Quote from: richhiway on June 19, 2022, 05:35:31 PM
Is there a kit you can get to convert one of those skill saws. Does it work pretty good ?
