Rolling guides on LT 40 Hydrolic
Started by calvin nelms, February 27, 2022, 07:00:29 PM
calvin nelms
Change bearing ( froze up) on idle side roller. Put it all back together and now the blade roller is not making enough contact to turn when blade is engaged. Checked the measurements ( from
 Arm all the way closed -1/2" to arm all the way opened) bed to blade and is correct. Blade guide measurement is true so I don't know what I did. Will
Contact Woodmizer Tech tomorrow but was wanting so Input from the group so I can work on it in the morning while waiting for a Tech.
Southside
Is there a physical gap between the roller and the band or is it just not turning?  If it's the latter did you get the felt washers on their correct sides?  It does make a difference.
White Oak Meadows
Ljohnsaw
Not sure why this is posted in the Woodland Mills area.  If you have this moved to the Woodmizer board, you might get better answers...
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
