Best slabbing chain cleaner that I have found
Started by blackhawk, April 28, 2022, 02:57:53 PM
blackhawk
I slabbed up two white oak logs this past weekend.  A total of 12 slabs, 10 feet long and average of 24" wide.  I used 2 chains and at the end of the day both had a lot of pitch/resin on them.  It was like a cured coating of polyurethane.  I tried kerosene, acetone, methyl alcohol, WD-40, and Goo-Gone.  None of them would cut through that film.  I was taking a razor blade to get it to come loose.
I then remembered that I had some Totally Awesome Cleaner that comes from Family Dollar and Dollar General.  I mixed some with water at about 20% ratio of cleaner.  I soaked the chains for around 30 minutes and I could brush them lightly with a brass brush and they came completely clean.  This stuff is $3.25 for a half gallon in my neck of the woods.  It is a great degreaser also.
Lucas 7-23 with slabber. Nyle L53 kiln. Shopbot CNC 48x96
trapper
