Drying rate question
Started by UpstateSC, May 03, 2022, 11:37:46 AM
UpstateSC
Hello, am getting close to finishing my small solar kiln, and I have a question about the max safe drying rate. The VT plans have a table for the max % loss per day that is safe. My question is about how this is calculated.
For example, if I have a board with 50% moisture and the max safe drying rate for the species is 5%, is it the calculation 50-5=45 or do I take 5% from 50 (50*95%=47.5)?
YellowHammer
50% MC in the board -5% moisture content  =45% moisture content in the board.
Next day, 45%-5%=40% and so on
Wood loses water fast when it has high moisture level, more slowly as moisture decreases.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
UpstateSC
Thanks. I figured it was that way but wanted to be sure.
