4 side planing cedar.
Started by customsawyer, August 28, 2022, 07:04:24 AM
customsawyer
I have a couple thousand bf of cedar to run through the 4 side planer. This will be a first time for me with cedar. Normally don't get enough cedar for this in my area. Just wondering if there is a higher chance of splits and cracks from the side heads. Will it be better going with a slower or faster feed rate? What other problems can come up?
www.thecustomsawyer.com
Southside
What I have run through didn't act any different than anything else.
White Oak Meadows
D6c
Assuming you mean eastern red cedar, the only problem I've had with ERC is if you get a loose knot it can be hard on cutters if it comes out.  I've had them break carbide inserts on a spiral cutter but not on straight knife heads.
Cedarman
We just ran 10,000 square feet of 9/16 x 3 1/2 and 4 3/4 V groove and had minimal amount of split out at edges and unsound knots will blow out.  But 9/16 is fairly thin.  1" lumber rarely a problem and we ran about 1000  3 1/2 x 5 1/2 and had no problems with pulls.
We use insert knives for top and bottom.
Don P
Way back before the turn of the century... I was working in a millwork shop. We did several runs where we took 4/4x5" ERC, split it both ways into 4 thin narrow strips and then ran a micro T&G V groove pattern as closet lining. The strips resembled a beadboard type pattern as far as busyness on the wall when applied. I expected high losses from blowouts but it machined quite well.
customsawyer
Appreciate the replies gentlemen. We are going to find out this morning.
Cedarman
You should have a pretty pink sawdust pile in a few hours.
Don P
That's right.., we would dump the dust truck before a cedar run and some of the guys would bag the shavings for home and friends. We never made more than that volume, but you can sell cedar down to the squeal.
customsawyer
Well I got it ran. Everything went pretty smooth until the last 12 boards. A few of them got hung up in the planer. They all had similar knots that would fall out in chunks and wedge the board in the planer. I would look at a board and think this is the same knot but it shouldn't fall out. Dang if it wouldn't. I didn't have any splitting on the edges from the side heads and the wood came out very nice for our poorer quality  cedar.
Cedarman
Poor quality cedar is cedar with lots of character.  Guy came back one time and wanted cedar with holes.  He painted the walls black before putting up the cedar and the knot holes looked great.  I did my best to satisfy him.
customsawyer
Cedarman I get that request with pecky cypress. Only have cedar when I have it. I have actually thought about calling you and getting some in for inventory for my store. Just never seem to get enough request for it.
Dewey
Quote from: Cedarman on September 04, 2022, 07:03:25 AM
Boy I could use some of those customers LOL
