Bark ID help
Started by Ar549, December 10, 2022, 08:15:42 PM
Ar549
I should've gotten a picture of the top as well.... Didn't.  I've narrowed it to basswood or White ash.  It's a blow down and it's been down a couple of years so the bark is darker than it would be I'm sure.  First branching is 30' up and the branches sweep up at a steep angle.
fluidpowerpro
I am by no means an authority on tree ID but I sure think that looks like the bark on an elm tree.
Change is hard....
Local wind direction is determined by how I park my mill.
rusticretreater
You should download one of the identification apps onto your phone.  Snap a photo, it searches and then IDs it for you.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Otis1
I wood lean towards elm also. If it's ash, then it will have opposite branches.
Good luck by bark alone. Up here sugar maple looks a lot different growing on glaciated sandy soil compared to sandy loam of potato field soil, for instance. About the only trees you can be sure of are the birches and even some folks can't separate grey from white birch. :D  Up here basswood bark looks like sugar maple bark on the same site. Young large tooth aspen with smooth bark and white blotches looks like young small blotchy sugar maple to. :D
large tooth on a maple-beech site.
Ar549
Thanks everybody.  Elm is the one tree I didn't search even though that crossed my mind when I first saw that it was down a long while back.  I'll take that into consideration.
Ar549
Quote from: rusticretreater on December 11, 2022, 12:38:49 AM
I did that but the results were very mixed.
Ron Scott
~Ron
doc henderson
if it is down can you get some close end grain, cut smooth like with a razor knife or a fine chop saw blade, and close up or even magnified pic of the end grain.  are the tops branches still on?  any leaves around from the tree?  what is the reason you want to know?  firewood, saw log?
KEC
Just from that photo, I would not rule out hickory.
WLzM1A
Quote from: fluidpowerpro on December 11, 2022, 12:30:25 AM
Agreed
Echo CS-310
Stihl 034 AV
Stihl MS250
Stihl 025
Echo CS-8000
Stihl 011 AVT
Stihl 066 Magnum
Dolmar PS-401
McCulloch MAC 160S
McCulloch Power Mac 6
Homelite Super EZ  X2
Homelite 330
Sears H58D
Whitehead 180 wall hanger
Poulan 220 Pro
Lone Elm British Labradors
AKC Fox Red and Black
Vet Owned
Autocar
It looks like pig hickory to me  :D .
Bill
KEC
If it is hickory, down for 2 years,  it is probably no good for lumber. Might make firewood.
